Posting a setup without cooling?
Go to solution Solved by RazrLeaf,
I'm at the stage where it can be usefull to turn the pc on and make sure everything works.
But right now so are there only passive cooling on the parts, with the water blocks mounted.
Can I post without ruining anything, and if so, how long do I have before heat fries my system?
Hardware list in the build log, in my signature.
You can post no problem. I did a post test with absolutely nothing on the CPU. It'll throttle itself back before it gets too hot, and it'll withstand short periods of 105 degrees Celsius without being damaged.
You've got 5 minutes easily with a copper block on it, probably 10-15. Just watch the temperatures once you get in to BIOS (upper left corner), and shut it down when it gets too warm for comfort.
P.S. I may have overestimated the times a little, but my point is that you have a lot more than 6 seconds. Just turn it on and pay attention.
https://linustechtips.com/topic/313632-posting-a-setup-without-cooling/
Titan: Intel Core i7-5820K | ASUS X99-A | Crucial Ballistix Sport 4x4GB DDR4-2400 | ASUS Strix GeForce GTX 970 | OCZ Arc 100 2x256GB in RAID 0 | Seagate Barracuda 2x2TB in RAID 1
EVGA SuperNOVA 750 G2 | Fractal Design Define R5 Titanium Window | Phanteks PH-TC14PE | ASUS BW-12B1ST
I belive it was Linus that said you should post a system to make sure everything is detected before mounting the tubes. As it is easier to deal with any problems that way.
But that was with a brand new system, my system has been running for the last 5 months.
So is it worth the risk or should I just go ahead and finish the build?
Most of the time you do a test boot before you put water blocks on anything. Which for X99 means a cooler-less CPU if you don't have a spare lying around. Which is what I did. xD
And if you've been running for 5 months already, just do a POST/make it to desktop to make sure everything still works and go on with your day.
I know that all the parts worked before I mounted the blocks, so the post is more to ensure that I did not ruin anything in the process or is not proper seated.
Yep. You've got it. It's a lot easier to reseat things when there aren't tubes in the way.
I would just put the stock heatsink on and run the test....unless you are running some of the x99 Intel CPUs as they don't actually come (at least some of them) with a stock heatsink.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
Might want to read again: I have already mounted the water blocks, meaning to using another cooler, so would I have to remove the blocks.
Which is for the First a lot of work, and for the 2nd counter productive.
Yeah that's why you run all your test/stability checks BEFORE you start mounting water cooling blocks....
In my case so has the system been running for 5 months, so I'm only interested in if anything has changed.
