http://pcpartpicker.com/user/Baionoido/saved/JwDfrH I'll be getting this, I'm not going for 16GB RAM straight away due to not decided yet if I will stream.
should be fine ^_^
i can stream perfectly fine with my 770 and 4690k w/ 8 gigs
https://linustechtips.com/topic/313541-does-obs-give-fps-drops/#findComment-4262235
Streaming, yes. You could use Intel QuickSync (assuming you're using an Intel processor, of course) to lessen the FPS drops. Not sure about recording, never used it.
QuickSync doesn't effect performance. Recording or steaming, you're still getting all the frames your system can make.
https://linustechtips.com/topic/313541-does-obs-give-fps-drops/#findComment-4262282
