Upgrade Solution
Go to solution Solved by Superfichtig,
@AFeralKitten if you want to OC go this way and reuse your heatsink to save money.
Updated with better psu.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.89 @ OutletPC)
Motherboard: ASRock Z97M Anniversary Micro ATX LGA1150 Motherboard  ($74.99 @ Newegg)
Video Card: Sapphire Radeon R9 280 3GB DUAL-X Video Card  ($159.99 @ Newegg)
Total: $509.86
Generated by PCPartPicker 2015-02-19 14:32 EST-0500
Current Specs:
AMD FX8320 @ 4.2GHZ Stable
CM HYPER 212 Evo
GTX 650 Ti MSI 2GB
8GB G.Skill 1600 MHZ
OCZ Vertex 2 120GB SSD, 1TB WD Blue
Some crap dell 350 Watt PSU (Traded a friend that needed an 8-pin CPU connector that my old PSU had)
I run 2 displays on @1080 and the other @720_
Location is Ohio, USA
If I save up I can spend around 450-500$ a month for upgrades I could spend more but my rent is outrageous
I heard Intel is the way to go but not sure if I should wait for SkyLake or nah.
 TL;DR What should I upgrade first? Then so on and so forth.
https://linustechtips.com/topic/313540-upgrade-solution/
I think you should think about investing in a better PSU before you think about a CPU.
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
https://linustechtips.com/topic/313540-upgrade-solution/#findComment-4262194
Current Specs:
CM HYPER 212 Evo
GTX 650 Ti MSI 2GB
The PSU. ASAP, some gold standard one from EVGA, or Corsair.
Then get a better gpu, r9 280x?
Intel processor. And z97 board.
Quote my post if you need me to respond.
https://linustechtips.com/topic/313540-upgrade-solution/#findComment-4262210
@AFeralKitten that would be a nice upgrade:
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($175.99 @ SuperBiiz)
Motherboard: Asus H81M-PLUS Micro ATX LGA1150 Motherboard  ($76.99 @ Mwave)
Total: $487.95
Generated by PCPartPicker 2015-02-19 14:17 EST-0500
Case: Corsair Obsidian 450D with 2x SP120 / 1x AF120 Mainboard: Z97 Msi Gaming 5 CPU: i7 4790K @4.0 Ghz CPU-Cooler: Noctua U14S RAM: 16 GB DDR3 Corsair Vengance 1600 Mhz GPU: Sapphire Vapor-X R9 290X HDD: WD Green 2 TB SSD: Samsung Evo 250 GB PSU: Corsair RM 750W Monitor: BenQ XL 2411z 144hz 1080p
https://linustechtips.com/topic/313540-upgrade-solution/#findComment-4262213
@AFeralKitten first i have recommended a non overclockable CPU because the question is would you really see an improvement? The i5 4440 is a great CPU and paired with a R9 280 will deliver a great gaming expierence.
https://linustechtips.com/topic/313540-upgrade-solution/#findComment-4262273
Total: $509.86
https://linustechtips.com/topic/313540-upgrade-solution/#findComment-4262311
I'll give you a bit of background on myself. Lower Class family, Mom+Dad in debt, Just out of high school. Nailed a sweet ass job at Rolls-Royce as a desktop engineer because I have MTA Security and Networking fundamentals. Moved out of moms house About a month ago and the rig I have now took me 2 years in high school to save up to get the parts. Because of this job I make 22.50$/Hr and can afford a new upgrade. I was an enthusiast while i was a kid and now I am an enthusiast with a pay check every two weeks.
TL;DR I was poor, Now I have steady income. I'm overclocking the shit out of everything
https://linustechtips.com/topic/313540-upgrade-solution/#findComment-4262317
Total: $509.86
Looks good, I will go with this one. Thanks mate!
https://linustechtips.com/topic/313540-upgrade-solution/#findComment-4262398
@AFeralKitten You are welcome! Have fun and enjoy your new system.
https://linustechtips.com/topic/313540-upgrade-solution/#findComment-4262481
