Ok, so. My Zalman MS800 Plus case does not come with front fan mounts which i find unusual as behind the front 3 bay covers there is a massive empty space perfect for an intake. So i decided to fit one. Now be warned, this is not the most aesthetic look in the world but it is behind the bay covers so will not be seen.
xaxc2o0.jpg?1
To make this I used: 4 pieces of Blue Tac
                                1 shoebox
Basically i attached blue tac between the cardboard spacers and the fan to steady it. Then underneath i cut out a piece of the cardboard and lay it down as a support. I was quite pleased with myself after doing this as i have never done case modding before.
Best of all this fan allows all of my components to run 6 degrees celcius cooler.
ALCATRAZ |   CPU: i9 9900k @ 5GHz, Motherboard: Asus Prime Z390-A, RAM: Corsair Vengence LPX 32GB, GPU: Gigabyte 1070Ti Case: Zalman MS800 Plus, Storage: Corsair 2TB NVME | Crucial M550 128GB SSD  |  WD 640GB HDD, PSU: XFX Pro Series 1050w, Display: ASUS MG279Q, Cooling: Noctua NH-D15
https://linustechtips.com/topic/313327-adding-a-front-fan-mount/
Azure Fists - "Grown men playing with each other since 2009"
CPU : Intel® Core™ i5-4590T, OS : Windows 10 64bit + Custom Alienware Console Interface, GPU : NVIDIA® GeForce® GTX 860M 2GB GDDR5, RAM : 8GB Dual Channel DDR3L 1600MHz, SSD : Kingston V300 240GB, WIFI : Intel® Dual Band Wireless-AC 7265 2x2 + Bluetooth 4.0, CASE : Alienware Alpha, PSU : External Power Brick, MOBO : Custom Dell Motherboard.
CPU : i5 6600, Mobo : Asus Z97i-Plus, RAM : 16GB DDR4 3000mhz Corsair Vengeance LED, GPU : Gigabyte G1 GTX 1080, Case : Silverstone RVZ02, Storage : SanDisk 1TB M.2, PSU : Silverstone Strider SST-SX700-LG, Display(s) : AOC Q2963PM 29" IPS Ultra Wide 21:9, Fans : Noctua NH-L9i with Be Quiet Pure Wings 2, Keyboard : Razer Blackwidow Stealth 2015, Mouse : Razer Naga 2015, Sound : LG Wireless Soundbar /Razer Kraken Pro, OS : Windows 10
https://linustechtips.com/topic/313327-adding-a-front-fan-mount/#findComment-4258956
That would be decent but why buy that when i have a shoebox and a spare 120mm fan lying around? :P
https://linustechtips.com/topic/313327-adding-a-front-fan-mount/#findComment-4258970
Well, it depends how much noise your solution provides, plus looks like there will be lots of places for dust to enter your case.
With the one I linked you can use rubber pins to reduce noise and also add a filter for dust.
Like I said my option is not ghetto, sorry :( *hangs head in shame*
https://linustechtips.com/topic/313327-adding-a-front-fan-mount/#findComment-4258979
Its hard to see from the image but every one of those bay covers has a built in dust filter which is also used as a noise dampener. So best of both worlds :)
https://linustechtips.com/topic/313327-adding-a-front-fan-mount/#findComment-4259000
I've had to do a similar thing with my Commander MSs-I since it doesn't support a radiator. I simply removed the DVD drive (I've got an external one that was for my dead laptop) and put it in the 5.25" bays, of course the only thing holding it in place is the dent I put in the top when I had a bit of a rage attack (lost connection in the middle of a large kill streak in Halo).
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/313327-adding-a-front-fan-mount/#findComment-4259070
