Hi guys, I'm new a this forum and also at pc building, but I,ve done some research and written a list of parts which I think are pretty good for what I want. Fist of all, I work with US currency and the one I calculated was about $3500, so anything in that range, maybe 500 or 1000 more wouldn't be bad. I am an arquitect so I'd use it mostly for 3D design and rendering, also some of video editing and working with large CAD and Max files, mostly a workstation. But I'm also intersted in gaming, not a priority, but I'd like to have the option to have a computer that can support great graphics for game as well as performance. I,m a mid-range to high gamer.
The pieces I gather are:
  • CPU. Intel Core i7 5930k
  • Motherboard. Asus X99 deluxe (also thinking about E-WS)
  • RAM. 4 RAM kit Corsair Vengeance LPX DDR4 - 32 gb
  • HDD.  Hitachi Deskstar 7k4000 - 4tb
  • GPU. 2 Geforce GTX 970
  • CPU Cooler. Be quiet Dark Rock
  • Case.  Fractal Design Define R5
  • Power Supply. Corsair Hx650
  • Monitor. Asus from PA series (I'd like to get two monitors)
And that's it. If there's something that will absolutely work for me, even though it's above the budget, I might consider it.
Thank you for your responses.
https://linustechtips.com/topic/313222-pc-building-plan/
You're not using enough additional PCIE lanes to need the 5930k. Just get the 5820k.
The PSU could be much better, and I recommend a 750W+ with dual GPUs, and you're running a more power hungry CPU than normal.
Your storage setup is a bit weird. Personally, I have a strong distrust of hitachi drives. If it were me, I'd get a BX100 SSD (250 or 500GB, depending on tastes) as your boot/primary drive, and a 3TB Seagate Barracuda as a mass storage drive.
https://linustechtips.com/topic/313222-pc-building-plan/#findComment-4257728
PCPartPicker part list: http://pcpartpicker.com/p/6hmtRB
Price breakdown by merchant: http://pcpartpicker.com/p/6hmtRB/by_merchant/
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor  ($548.99 @ NCIX US)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($99.99 @ Newegg)
Motherboard: Asus X99-DELUXE ATX LGA2011-3 Motherboard  ($361.00 @ Directron)
Memory: Crucial Ballistix Sport 32GB (4 x 8GB) DDR4-2400 Memory  ($397.98 @ Newegg)
Storage: Samsung 840 Pro Series 256GB 2.5" Solid State Drive  ($197.89 @ OutletPC)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($92.63 @ Amazon)
Video Card: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card  ($549.99 @ NCIX US)
Case: be quiet! Silent Base 800 ATX Mid Tower Case  ($119.90 @ Newegg)
Power Supply: Corsair 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($199.99 @ Amazon)
Total: $2568.36
Generated by PCPartPicker 2015-02-19 01:07 EST-0500
Cheaper and better.  Way over kill psu, and cpu.
sold
https://linustechtips.com/topic/313222-pc-building-plan/#findComment-4257752
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($54.99 @ NCIX US)
Motherboard: ASRock X99 Extreme3 ATX LGA2011-3 Motherboard  ($146.78 @ Newegg)
Memory: Mushkin Blackline 32GB (4 x 8GB) DDR4-2133 Memory  ($415.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($119.61 @ Amazon)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($204.99 @ Amazon)
Storage: Toshiba  4TB 3.5" 7200RPM Internal Hard Drive  ($156.39 @ Amazon)
Video Card: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card (2-Way SLI)  ($549.99 @ NCIX US)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.99 @ NCIX US)
Total: $2937.70
Generated by PCPartPicker 2015-02-19 01:21 EST-0500
https://linustechtips.com/topic/313222-pc-building-plan/#findComment-4257798
Given the work described I do think a Quadro gpu would be the best choice. I don't think there is any way to get around the faster and more accurate work of a workstation gpu. The Quadro K4200 would have gaming performance a bit lower than a GTX 760.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($369.88 @ OutletPC)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($61.99 @ Newegg)
Motherboard: Asus X99-A ATX LGA2011-3 Motherboard  ($249.99 @ Amazon)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2400 Memory  ($409.99 @ Amazon)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive  ($419.99 @ Amazon)
Video Card: PNY Quadro K4200 4GB Video Card  ($774.99 @ Amazon)
Case: Fractal Design Define R5 (Black) ATX Mid Tower Case  ($107.99 @ SuperBiiz)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.99 @ SuperBiiz)
Monitor: Asus PA279Q 27.0" Monitor  ($812.98 @ Directron)
Total: $3380.42
Generated by PCPartPicker 2015-02-19 02:04 EST-0500
https://linustechtips.com/topic/313222-pc-building-plan/#findComment-4257970
