Im new here but have been a fan of tech tips for a while now.
My friend told me his fans were running loud so I asked him for some CPU temps. (See picture for details)
He keeps his computer on 24/7 against my warnings and there were very few programs running at the time.
How can I get more information about his situation?
What should I advise him to do?
I told him already to turn it off or take of the side panel to lower temps.
Thanks for any and all help.
J.
https://linustechtips.com/topic/311828-hot-cpu-please-advise/
Those temps aren't bad (if at load, and using the stock cooler).
See what's actually running....there may very well be something running in the background he doesn't realize.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/311828-hot-cpu-please-advise/#findComment-4238147
maybe the thermal paste dried out or the heatsink is not installed properly
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/311828-hot-cpu-please-advise/#findComment-4238148
Replace the thermal paste and clean out the dust of the PC using compressed air
https://linustechtips.com/topic/311828-hot-cpu-please-advise/#findComment-4238176
I can't tell you how many computers I've dealt with that were running slow when "nothing" was running...
A lot of times when people have issues, it's rooted in the fact that a ton of shit is running in the background and they don't even realize.
PSU Tier List | CoC
https://linustechtips.com/topic/311828-hot-cpu-please-advise/#findComment-4238183
What CPU?
2600k
PSU Tier List | CoC
https://linustechtips.com/topic/311828-hot-cpu-please-advise/#findComment-4238189
1. He is checking his background processes.
2. I am giving him my cooler master cpu cooler (Yes he has the stock one). And also I am making sure he uses fresh thermal paste to make sure the heat distribution is good.
3. Ill update you on the background processes.
Thanks for all the quick responses guys.
J.
https://linustechtips.com/topic/311828-hot-cpu-please-advise/#findComment-4238458
It looks to have been a temporary load. Not sure why the temp went up that high though...
He found some dust build up after he opened up the case, most of witch is gone now.
These temps look a lot better even with the crap picture quality.
Thanks again.
J.
https://linustechtips.com/topic/311828-hot-cpu-please-advise/#findComment-4238472
