HELP GPU Low Clock Speed
Go to solution Solved by ExcitezR,
its in power save mode when at the desktop to keep temps down if it stayed at boost speed all of the time it would idle at like 60c
I monitor my GPU and CPU with Windows 7 desktop gadgets that use PCMeter.
Today I noticed that the GPU clock only shows 324MHz, so I loaded up GPU-Z to check and same again...
My GPUs core clock speed should be 1072MHz and boost should be 1137MHz, what's happened?
This is the exact page I ordered my GPU from: http://www.novatech.co.uk/products/components/nvidiageforcegraphicscards/nvidiagtx660series/02g-p4-3063-kr.html
https://linustechtips.com/topic/311470-help-gpu-low-clock-speed/
that is the maximum speed ,during 2D work gpu wont be pushed hard for it to reach to maximum speed.
https://linustechtips.com/topic/311470-help-gpu-low-clock-speed/#findComment-4233369
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/311470-help-gpu-low-clock-speed/#findComment-4233391
Just me being stupid then, never really noticed it before....
https://linustechtips.com/topic/311470-help-gpu-low-clock-speed/#findComment-4233402
There saving power.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/311470-help-gpu-low-clock-speed/#findComment-4233408
lol it cool you learnt something new today i guess remember to mark as solved if it helped
PC PART PICKER
https://linustechtips.com/topic/311470-help-gpu-low-clock-speed/#findComment-4233411
