|HELP|
Solved by UltraNeonGaming,
Hello Linus Community!
I wanted the monitor above but the resolution is
1920x1200 - As I produce YouTube content what effect will this have on 1080p uploads and do you suggest any other monitor over those? I am looking to buy two and they seem solid both.
Budget: £400 for two monitors
Thanks!
Yes it will have 1080p support, it is slightly taller than 1080p which is 16:9 and this monitor is 16:10.
So meaning if you play your games at 1080p 16:9 you will get pure 1080p and not 1200p but you will have some black bars at the top and bottom of your monitor, they won't be in the video because the video will be 16:9, but they will be on your monitor which is running at 16:9 instead of 16:10
