Hey guys,
are any of you aware of how I can boot different operating systems from different drives in 1 PC?
I would like to make it as easy to select as possible as my gf uses my PC when I am at work and I would prefer that her stuff is not on my HDD. She tend to virus things up a bit :)
Anyway so what I need is this.
Everytime the PC is powered on I want it to ask what HDD or SSD to boot off.
It would be great If they could be named so it is simple to do.
Thanks in advance
My rig:
CPU: i7 4790k @4.5ghz (1.165v) COOLER: Hyper 212 Evo  MOBO: Asus Maximus VI EXTREME   RAM: 8GB Kingston FURY @1866 Mhz   GPU: ASUS STRIX GTX 970 DUAL SLI   PSU: Corsair HX750   CASE: NZXT Phantom 830 HDD: WD Black 3TB SSD: Samsung 840 EVO 256Gb
https://linustechtips.com/topic/311015-dual-boot-system-help/
windows 7 and windows 8.1 on different drives
My rig:
https://linustechtips.com/topic/311015-dual-boot-system-help/#findComment-4226984
May I ask how the OS i will be using is relevant to the Booting of those drives?
My rig:
https://linustechtips.com/topic/311015-dual-boot-system-help/#findComment-4227224
1. Install both OS on individual HDD (Make sure only one HDD is connected for each installation)
2. Goto BIOS/UEFI select the HDD you GF frequently uses as the defaut boot HDD
3. When you want to use yours press F2/F11 or what ever the key is for you MOBO to select the boot drive and select your HDD
Does this help?
https://linustechtips.com/topic/311015-dual-boot-system-help/#findComment-4234056
