It was working just fine and I installed an update and after the update it worked just fine then the computer froze a while after and now its not even installed but ti shows up as being installed and everytime i try and uninstall/ install it gets a fatal error at the end and doesn't work.
​ITS DRIVING ME INSANE!!!!!!!!!!!!!!!!!!
https://linustechtips.com/topic/31098-virtualbox-wont-work-for-no-reason/
Try performing a System Restore.
Or going to the registries, delete the entries, and use CCleaner to try and unninstall.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
