So last night i got this notification from windows saying that one of my usb port had a power surge, its was the usb port that i had my headset plug into. They stopped working so i decided to turn off my comptuer and deal with it the next morning. But today when i go to turn it on it wont even power up. i unpluged everything and tryed to switch outlets but nothing please help !!!!!
https://linustechtips.com/topic/310859-computer-will-not-turn-on-help/
is your mobo messing with ya?
If you can get the qcode readout, check it against the manual
i7-5930K@4.7Ghz | Asus X99-E-WS/USB 3.1 | Corsair Vengance 32GB DDR4@2666Mhz | Duo Gigabyte GTX 1080 Xtreme Gaming | Samsung 950Pro 512GB | LSI 9260-8i RAID Card | 6x 1TB Samsung 850 Pro (RAID5) | Corsair AX1200i |  Fractal Design Defiine R5 Black | MetaDot DasKeyboard4 Professional | Logitech G900 | Windows 10 Pro 64-bit | Asus PG348Q
I have no idea what a qcode readout i
Some motherboards have a little display embedded that shows two digit codes that represent an outcome.
