I can't access LTT on my phone using tapatalk, but can connect to other forums with it.
Anybody having this issue, and possible solution.
PS: Re-installing the app did't help.
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
https://linustechtips.com/topic/310763-tapatalk-problem/
Tapatalk is currently unsupported on the forum because it was causing some issues. Once tapatalk release an update to resolve the issues, it is likely to be re-enabled, but until then you're just going to have to use the web version.
HTTP/2 203
https://linustechtips.com/topic/310763-tapatalk-problem/#findComment-4224035
