I have recently started programming in python and I decided to tackle a small project, there won't be any graphics or pictures just a questionnaire that guesses your age.
This question is kind of a tough question to put into words so bear with me   :P.
Essentially I need to know how to make it to where if a person replies "yes" to a certain question then a certain number is put into a mathematical equation and a different number that goes into that equation if they were to reply "no".
For Example: say, Yes = 1  and No = 2
If they typed Yes than they would get the answer "2" (1+1)
If they typed No then they would get the answer "3" (2+1)
If that was a little tough to understand I apologize and please don't hate, I've only just started in Python.
Thank You!
https://linustechtips.com/topic/310475-python-help/
x=raw_input()int numberint answerif x=="yes":    number=5elif x=="no":    number=6answer=number+10print answer
I havent done python in a year so there may be some tiny bugs...
https://linustechtips.com/topic/310475-python-help/#findComment-4220057
Thanks I'll try it out and let you know if it worked, and I had one more question. Do the order of operations apply in Python?
https://linustechtips.com/topic/310475-python-help/#findComment-4220100
You're welcome, let me know how it goes.
Yes python knows BEDMAS, but you can always use brackets () to make sure everything is done in the order you want
https://linustechtips.com/topic/310475-python-help/#findComment-4220145
Thanks and how do I make the things that are printed show up one at a time (it only works on the first one for some reason)?
https://linustechtips.com/topic/310475-python-help/#findComment-4220171
You mean like on a new line each time?
do
print "\n"
for a new line :)
you can also do
print "hello there\nthis is now a new line"
and the stuff after \n will be on a new line
https://linustechtips.com/topic/310475-python-help/#findComment-4220184
do
print "\n"
for a new line :)
you can also do
Lol I figured it out  and no, I was talking about when a question is asked you answer it then a second question is asked and so on. But I already figured it out (it was a comma)
https://linustechtips.com/topic/310475-python-help/#findComment-4220221
It is say that int number is an invalid syntax.
k then do
number=0
or try just
https://linustechtips.com/topic/310475-python-help/#findComment-4220261
x=raw_input()
int number <--------- not needed
int answer <--------- not needed
if x=="yes":
    number=5
elif x=="no":
    number=6
answer=number+10
print answer
hey guys, In python you do not have to initialize a variable before it's use or define it's type. All of this is done at the time of first assignment, also everything is an object with a type so can just change at any point.
like this.
number = 0number = "string"
So when I do the first line the variable number is an object with the assignment of 0 and it's type is int. then when I reassign this, the value and the type of the variable change to "string" and string respectively but it is still an object.
this theory goes right the way through python, from classes, to functions, to variables, everything is a object with a type.
https://linustechtips.com/topic/310475-python-help/#findComment-4223168
k then do
number=0
or try just
Like said in the above post, you don't need to define a variable before you assign it a value in Python. Just leave that code out, as it has no real purpose and is just extra unneccessary code in your program.
CPU: AMD FX-6300 4GHz @ 1.3 volts | CPU Cooler: Cooler Master Hyper 212 EVO | RAM: 8GB DDR3
Motherboard: Gigabyte 970A-DS3P | GPU: EVGA GTX 960 SSC | SSD: 250GB Samsung 850 EVO
HDD: 1TB WD Caviar Green | Case: Fractal Design Core 2500 | OS: Windows 10 Home
https://linustechtips.com/topic/310475-python-help/#findComment-4228299
sorry ive been doing c++ for a year and i kinda forgot python :P
https://linustechtips.com/topic/310475-python-help/#findComment-4228310
