When I turn the system on, I get dr debug codes 54 and 55, which mean: (quote)
01 - 54 (except 0d), 5A- 60 Problem related to memory. Please re-install the CPU and memory then clear CMOS. If the problem still exists, please install only one memory module or try using other memory modules.
55 The Memory could not be detected. Please re-install the memory and CPU. If the problem still exists, please install only one memory module or try using other memory modules.
Has anyone had this, will I have to reinstall my CPU like it says? How bad is this error?
I haven't tried anything yet, I'm going to have to wait until later when I have more time.
Thank you.
Current Rig : Corsair 330r, ASRock Z77 Extreme6, 3570K, 8gb Crucial Balistix, KFA2 GTX680 White, Corsair AX750, Xonar Essence STX, Beyerdynamic DT770
https://linustechtips.com/topic/30998-asrock-extreme6-not-posting/
If you take out the CPU, check the pins for any kind of dust. And if your motherboard isn't posting, then it's pretty bad.
first I would try to take out one stick of ram and see if it boots.
if not take that stick out and replace it with the other stick of ram.
if it still doesn't boot try removing the graphics card and booting off the IGP
if it still doesn't boot try removing the motherboard from the case and see if it boots while  assembled on the motherboard box.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
Alright, I'll do that first before getting the CPU out, I really hope it's just memory related
The thing which worries me the most is that while I was gaming, it started making this wierd grinding noise and it froze. I switched it off and left it for a bit. Then when I turned it back on it have me those errors. Could it be a PSU fault?
My mobo isn't posting either, i'm not getting any beeps or error codes and its just a black screen so i have to RMA my board, bios is corrupt for me, though it could be different fro you since your getting error codes
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
Where did the noises come from?
I don't know exactly but I think they were from the machine itself cause when I switched it off they went too.
@Snickerzz it sucks doesn't it. I only bought it in January. I think this is the single flaw in building your own rig is that when it breaks it's up to you to trouble shoot and deal with it.
yea :/ i bought mine almost exactly a year ago, it failed 2 days ago and i bought it july 7th 2012 XD
Well I hope yours turns out alright, I'm gonna begin with all the things said here tomorrow morning. It's half past midnight here XD
me too, sleep well :)
I have taken out on Dimm of memory and moved the other into a different slot. It posted so i put in the other Dimm in the other channel. So now it's posting as before.
Thanks a lot guys! XD
I had the same problem , my mobo didn't want to post en i ripped my system apart and made a test-thingy with only cpu ram mobo and power suply and then it posted and then i installed it in the case and plugged in a cable and post after 1h the problem was a USB2.0 front panel connector , if I plug it in my mobo won't post maybe u have the same problem try to unplug al the front panel things and the first time my mobo won't post i had the same problem with memory dimms
6600K  |  16GB HYPERX  |  GTX1070 FE  |  Z170X-UD3  |  AIR540
Respect the past, Embrace the future.
