Hi 6 months ago my pc, when its plugged in motherboard lights is working but to start it had 30 min delay. and like that for 2 months til it stopped working the mother board lights was working but it did not started. i wanna ask if any buddy know what could be the problem. my guess psu but im car expert not pc. sorry  for clishe gramma.
https://linustechtips.com/topic/309734-pc-not-starting/
are there any error codes on your MoBo like a little display or ,if you have it plugged in, a beep code from the little speaker?
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/309734-pc-not-starting/#findComment-4210268
when i turn my psu on the MoBo lights goes on but when i try to start it does not make a sound of beep. as i said i think that psu is broken and dose not supply enough power to start. i just need to know if its true that it could psu's fault.
my pc is simple i was using just for working (solid edge) and school.
and for grammar im european.
https://linustechtips.com/topic/309734-pc-not-starting/#findComment-4216723
