network speed
Go to solution Solved by Abir Vandergriff,
How do I measure it? What tool?
Just a guy who peaked at building back in the days of the GTX 980. If you see me here, assume i have technical knowledge akin to a committed hobbyist builder back then. If something's changed, you'll need to tell me(nicely plz). I'm probably asking for help with the modern build scene since I have no clue what's going on.
https://linustechtips.com/topic/309485-network-speed/
What unit I'd it measuring in?
https://linustechtips.com/topic/309485-network-speed/#findComment-4206728
Most likely Megabits per second. Notably not Megabytes. If you divide your result by 8 you'll get your speed in Megabytes per second.
CPU: AMD 5800X
GPU: Gigabyte Aorus 3070 Ti
SSD: WD SN850X 4TB x2
MoBo: Gigabyte Aorus Master B550
Case: Fractal Torrent
PSU: EVGA Supernova G2 750W
https://linustechtips.com/topic/309485-network-speed/#findComment-4206734
