Hello all,
I was wondering if anyone knows of any braided cable accessory kits similar to that of Corsairs cable kits for the Seasonic X-760.
Thanks
Chris
7900X, Asus X670-E ROG Strix , 32GB Corsair Vengeance RGB DDR5 6000, 2 x Samsung 980 Pro 2 TB NVME, Samsung 980 Pro 1TB NVME,  EVGA RTX3080TI FTW3
EVGA Supernova P2 1000 PSU w/ CableMod, Asus Xonar DSX, Lian Li Galahad 360, Hyte Y60, Corsair K70, EVGA Torq X10, (1) Alienware AW3418DW Ultrawide, (1) Acer Predator XB271HU 1440P, Logitech G535
https://linustechtips.com/topic/308642-seasonic-x-760-cable-kit/
you have a few options
you can sleve them yourself ( can be tricky and time consuming)
you can buy sleeved cables from someone like sanctum sleeving ( Can be very expensive )
or you can go with sleeved extensions like these http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=silverstone+sleeved+extentions&N=-1&isNodeId=1
https://linustechtips.com/topic/308642-seasonic-x-760-cable-kit/#findComment-4194730
My apologies on the repost.  Work internet dropped and it posted a second time I think when it came back up.
I am using extension now, but its a bit annoying with cable management, especially behind the motherboard tray.
May just swap to a Corsair HXi or Axi and get their kit.
https://linustechtips.com/topic/308642-seasonic-x-760-cable-kit/#findComment-4195580
