so i got this build (http://uk.pcpartpicker.com/p/KWB423) (already have the case) and my questions is
Should i go for the Antec  650 gold psu which is not  modular or the cxm 600 bronze which is semi-modular
Should i go for the  Gigabyte Z97N-WIFI which has the main connectors to the side or there is enough space in the 250d for the H60 and the connectors with the MSI Z97I AC
I believe 600w is enough for my build if you disagree plz suggest something else
CPU:Intel I5 6700k (4.7GHz)  Mobo:Asus maximus viii hero RAM:HyperX 16GB  GPU:MSI gtx1080 Gaming X
Case:Fractal Design Define S SSD:Kingston 240GB HDD:1TB & 2TB raid 0 PSU:Corsair RMX750 Cooling:H100i v2 OS:Windows 10
Display:Benq GL2440,LG 29" Keyboard:Tesoro Durandal Mouse:Deathadder Sound:2.1 GENESIS NCS-0856, PC-37X, Razer manowar
https://linustechtips.com/topic/308629-m-itx-build-250d/
I would go with a modular PSU for sure, got the case myself and I can't really imagine without a modular PSU. For the MOBO, there is alot of space so MSI should work.
https://linustechtips.com/topic/308629-m-itx-build-250d/#findComment-4194562
Let's be real: for 10£ extra, you can step up to a 970, and have an easier time with heat and PSu requirements.
As a note, I added a 650w Gold Fully modular PSU.
And, the best CPU cooler in existence. Don't worry, it'll fit inside your case just fine.
Do you need storage?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£181.18 @ YoYoTech)
CPU Cooler: RAIJINTEK TRITON 100.5 CFM Sleeve Bearing Liquid CPU Cooler  (£79.55 @ Overclockers.co.uk)
Motherboard: MSI Z97I AC Mini ITX LGA1150 Motherboard  (£89.68 @ Amazon UK)
Memory: Kingston Fury Red Series 8GB (1 x 8GB) DDR3-1866 Memory  (£51.46 @ Amazon UK)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  (£279.98 @ Novatech)
Case: Corsair 250D Mini ITX Tower Case  (Purchased For £0.00)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£63.31 @ Amazon UK)
Total: £745.16
Generated by PCPartPicker 2015-02-11 18:55 GMT+0000
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/308629-m-itx-build-250d/#findComment-4194612
Total: £745.16
1 i have storage
2 if i am gonna use a 970 i will probably go with a 500watish psu
3 i am buying from amazon and the build should be at  £700 max
https://linustechtips.com/topic/308629-m-itx-build-250d/#findComment-4194678
1 i have storage
1 - Should have said.
2 - Well... to go with a 500w psu, you'll have to give up on 80+gold or modularity. Because the cheapest +gold modular PSU is that 650w one.
3 - If you were going to buy only form amazon, why did you list other stores in your build?
Okay.... I'll help you.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£183.00 @ Amazon UK)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  (£50.99 @ Amazon UK)
Memory: Kingston Fury Red Series 8GB (2 x 4GB) DDR3-1866 Memory  (£49.99 @ Amazon UK)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  (£279.99 @ Amazon UK)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£49.00 @ Amazon UK)
Total: £702.65
Generated by PCPartPicker 2015-02-11 19:13 GMT+0000
https://linustechtips.com/topic/308629-m-itx-build-250d/#findComment-4194734
Total: £702.65
To be honnest 80+ isn't that important, it's more depending on how expensive electricity is where you live.
https://linustechtips.com/topic/308629-m-itx-build-250d/#findComment-4194778
