Budget pc build. Need some help.
Go to solution Solved by stconquest,
No USB 3.0 on the front(case):
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  (€120.89 @ Amazon Deutschland)
Motherboard: ASRock H81M-DGS Micro ATX LGA1150 Motherboard  (€44.99 @ Amazon Deutschland)
Video Card: Gigabyte Radeon R9 270 2GB WINDFORCE Video Card  (€166.81 @ Amazon Deutschland)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  (€56.94 @ Home of Hardware DE)
Total: €389.63
Generated by PCPartPicker 2015-02-11 20:11 CET+0100
USB on the front(case):
Motherboard: ASRock H81M-HDS Micro ATX LGA1150 Motherboard  (€50.90 @ Amazon Deutschland)
Total: €395.54
Generated by PCPartPicker 2015-02-11 20:13 CET+0100
Hello, this is my first pc build.I'm gonna use it for about 3years.It's mainly for gaming/surfing the net. Parts:
CPU:AMD FX-6300
GPU: Asus R9 270
Motherboard: Help, I don't now really what mob woud be great. I want a cheap one and that I could OC.
RAM: Adata Premier Series DDR3 1333Mhz 8gb 1x
PSU:  PSU be quiet! System Power 7 - 500W, 80PLUS Silver
Space: Old HDD
OS: Windows 8.1
Case: Old case.
If you have any ideas, that can help my build tell me :)
https://linustechtips.com/topic/308622-budget-pc-build-need-some-help/
i5 4460 and a cheap H97/Z97 board if you can afford it.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($100.95 @ SuperBiiz)
Motherboard: MSI H81M-E34 Micro ATX LGA1150 Motherboard  ($44.99 @ SuperBiiz)
Video Card: Asus Radeon R9 270 2GB DirectCU II Video Card  ($140.99 @ SuperBiiz)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.99 @ Newegg)
Total: $326.92
Generated by PCPartPicker 2015-02-11 13:38 EST-0500
Check the power supply watts calculator
http://extreme.outervision.com/psucalculatorlite.jsp
Why?  Check load power consumption for the particular GPU you pick, that is much better...R9 270 = max 250w.  I like an extra cushion for the system, 150w (really don't need that much).
500w, 80% effiency...400w... Perfect!  =)
I'm not gonna upgrade, I will use it for about 3years becouse I'm going to school, and when I will be a student I will leave my place.
i3 will be faster than the FX-6300.  Don't think of that AMD CPU as a 6-core... it is like having 3 cores, with 2 weaker cores inside each core.
Most games prefer single core performance, not how many cores they are.
If you mostly do multitasking and game occaisionally, then go with your current one.
If you play games quite a bit then go for i3 as games prefer Intels single core performance.
Then don't think of an i3 as a quad core ;)
This is $80 over budget ($450)
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($171.99 @ SuperBiiz)
Total: $397.96
Generated by PCPartPicker 2015-02-11 13:49 EST-0500
I don't.  I think of the i3 as a capable dual core, with a little extra performance in parallel processes.
Good boy ;)
Total: $397.96
I live in EU, so the price is not the same :/
What is the performance difference? And new realeased games will not take benefite of more cores?
No. My i5 destroys the AMDs closest equivalent which has 8 cores (albeit 4 are hyperthreaded but still)
Most game devs focus on single core performance instead of how many cores.
Much better performance to be had.
Possibly, but not slow cores. i3 will be best for you, as it has very strong single core performance and more games are Intel optimized than AMD optimised. Also, some games like hyper threading now which the i3 has.
But, can you OC i3? Becouse I will OC everythink.
Price is very similar:
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  (€174.90 @ Caseking)
Total: €443.64
Generated by PCPartPicker 2015-02-11 19:56 CET+0100
No there is no unlocked i3.
There is a Pentium unlocked which is an overclockable i3 without hyper threading but most games need a quad core nowadays so I don't recommend it.
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  (€63.90 @ Caseking)
Total: €450.60
Generated by PCPartPicker 2015-02-11 19:55 CET+0100
I don't have a job, I go to school, and 100eur difference is big for me. And I will use this pc for only 3years
