Hey guys, i made an account here since i thought you guys might have the best advice for me.
I've recently wanted to led-light my desk, just a few nice, green LED's around it, so the back edge glows and below it glows.
Problem is, i know little to squat about even making an LED work well.
Simple as that, i want to power a couple of LED'S cheaply.
Is it possible for me to get a few of them, get a couple of battery packs and get it to work? If so, what kind of batteries do i need, also, how long would an LED light last with the batteries?
If i didn't make much sense please do tell me, otherwise, i'll await an answer, thank you in advance. :)
https://linustechtips.com/topic/308618-led-light-a-desk/
Led are simple you can get a strip like this http://www.amazon.com/SUPERNIGHT%C2%AE-Waterproof-Flexible-300leds-Changing/dp/B00ASHQQKI/ref=sr_1_2?ie=UTF8&qid=1423679728&sr=8-2&keywords=Led+strip
and never have to worry about it
the strip you can cut to length and solder on a 12v DC connector (one usually comes with it pre installed ) But if you don't want that I could make you one that is to what ever lingth you want and what ever color. also to power most Led strips it takes 12V DC
https://linustechtips.com/topic/308618-led-light-a-desk/#findComment-4194462
get a 5m led strip rgb with remote from ebay with free shipping anywhere.you can cut it at the desired lengh or whatever. then just buy a 12V power adapter with 2A+ and ur good.very cheap.5050 leds are very good and bright
http://www.ebay.com/sch/i.html?_odkw=led+strip+5050&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xled+strip+5050+rgb&_nkw=led+strip+5050+rgb&_sacat=0
https://linustechtips.com/topic/308618-led-light-a-desk/#findComment-4194793
I bought an rgb led strip off amazon and used sellotape to keep it in place. Will post a link and take a photo for you to see an example. Very amatuer one :D
I got this one: http://www.amazon.co.uk/gp/product/B00JY73XCM?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
The colour set in the photo is bright purple and i got it pretty close to the wall (2inches away) so it looks white on photo but in reality its not as white :) My led strip is attached to the edge of the desk.
post-28682-0-27201700-1423710287_thumb.j
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/308618-led-light-a-desk/#findComment-4195453
The one you linked does come with the connector already installed, it is just plug and play. If you ever need them though, they now make these: http://www.amazon.com/AspenTek-Connector-Conductor-Connecting-Controller/dp/B00G1BYJQS/ref=sr_1_7?ie=UTF8&qid=1423696652&sr=8-7&keywords=rgb+led+adapter
No soldering required.  :D I've recently started using them, they work really well and are a huge time saver. You can get them for directly connecting lengths of LEDs together, or ones that are a few inches long for bending around corners, as well as ones for single color LEDs that adapt to a DC barrel plug.
https://linustechtips.com/topic/308618-led-light-a-desk/#findComment-4196541
