Every video i see, people test that there mobo will post, before they install it into the case. They install the stock cpu fan before they install any other aftermarket fan/cooler. My issue is that i dont have a stock fan. All i have is a h100i. my mobo is a x99 and cpu is 5820k. What would be my best option to test the mobo? Should i install everything in the case and attach my h100i in case in hopes that is post's or should I put it together with the h100i outside of the case then take it apart, reapply thermal paste and finally install if it does indeed post? I'm not really sure what i should do.
https://linustechtips.com/topic/308114-testing-a-mobo-with-cooling-kit/
I'd just throw it in the case and hope for the best.
/you can also put the h100i on it, test it and then just put the h100i and mobo in the case all at once (you don't have to remove it).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
just put the basics in the case and test it. that way you will only have to take it apart if it doesnt work, not a guranteed take it apart.
people only do that because its easier to take it apart if something doesnt work. I personally just install and run it all in the pc, because not every rig needs a RMA
I'd put on the H100i without fans, plug it in and run your test. When you put everything into the case, let a friend help you. He should hold the H100i while you lay down the motherboard and screw it in. Then screw in the H100i with the fans.
who cares...
