Doing my first watercooled build here shortly, not entirely sure where to start looking for equipment, almost as overwhelming as when i first started building systems lol.
I was hoping that the community would be able to point me in the right direction.
What would I be looking for if I want a high quality, quiet loop for a CPU and a CPU,
I have room in my case for 2 360mm Rad's, and would prefer to cool them with bit fenix spectre pro blue led fans, (unless that will work poorly)
All help appreciated
Please be constructive I do not want to go with an AIO.
https://linustechtips.com/topic/307994-new-to-water-cooling/
well first off all get 2 360mm rads.And make sure to have ample airflow over your motherboard as well.Secondly buy the waterblocks for your cpu and gpu.Next get a resorvoir which you like
(If you will be showing it off).After that all you need is some tubing and compression fittings.Make sure the inner diameter and outer diameter of your tubing is compatible with the fittings you buy.
Please tell me your hardware specs if you want me to build a rig for you.
https://linustechtips.com/topic/307994-new-to-water-cooling/#findComment-4185636
I will assume you mean a CPU and a GPU.
For parts, I personally prefer EK Water Blocks Supremacy EVO (a CPU block) and their FC (full cover) GPU blocks. and Alphacool NexXxos Radiators. You're in Canada, so I can't help you with retailer.
You'll also need a pump (EK-D5 series, Swiftech MCP655, or any Laing D5 variant) a reservoir (bay or tube, or res/pump combo unit), tubing, and fittings.
For fittings, you're going to want compression fittings. Monsoon and Bitspower are good for those. Primochill Advanced LRT seems to be the best flexible tubing at the moment. There are many choices for reservoir, but I personally like EK's Res X3.
You'll have to give us all your specs for us to help you further.
Titan: Intel Core i7-5820K | ASUS X99-A | Crucial Ballistix Sport 4x4GB DDR4-2400 | ASUS Strix GeForce GTX 970 | OCZ Arc 100 2x256GB in RAID 0 | Seagate Barracuda 2x2TB in RAID 1
EVGA SuperNOVA 750 G2 | Fractal Design Define R5 Titanium Window | Phanteks PH-TC14PE | ASUS BW-12B1ST
https://linustechtips.com/topic/307994-new-to-water-cooling/#findComment-4185645
Thanks,
why alpha cool radiators?
They're entirely copper, they use as little paint as possible, they have lots of openings, they have 4 different thicknesses, and they have an extra lip that goes around the edge that prevents you from driving a screw in too far, protecting the actual radiator. This applies to the NexXxos line only lol.
https://linustechtips.com/topic/307994-new-to-water-cooling/#findComment-4185699
Im well aware that thats what is needed, what im looking for is opinions on brands, fans, pumps and fittings that are high quality.
Specs I7-4770k, Asrock z97 Xtreme6, EVGA GTX 980, 16GB (8x2) 2133 Gskill Ares DDR3, NZXT h440, Corsasir 1000w RM PSU
https://linustechtips.com/topic/307994-new-to-water-cooling/#findComment-4185715
So any variant of the EK-FC980 GTX will suffice (purely aesthetic differences). A backplate is optional, but nice. Any EK Supremacy EVO as well.
The stock NZXT fans are actually quite good, so if you're OCD like me, I'd just get another 3 of them for the top radiator (so they match the rest).
Like I said with pumps, any variant of the Laing D5 is excellent, though the Swiftech MCP655 and EK-D5 are the most popular (and even have PWM versions).
Bitspower and Monsoon have some of the best fittings out there, but they are expensive. I personally like Monsoon's free center fittings the best, and they come in 6-packs with a wrench that can make life easier.
https://linustechtips.com/topic/307994-new-to-water-cooling/#findComment-4185780
Water blocks (CPU)-XSPC raystorm or any EK one
Water blocks (GPU)-Alphacool nexxoss
Rad-Get one with a full copper interior (it will be mentioned on most sites)
Pump-Any D5
Tubing-Well get anything you like.
Coolent-You can buy premade ones but just get distilled water some anti corrosives and a piece of 99% silver and stick it in the res.You can add dyes as well.
https://linustechtips.com/topic/307994-new-to-water-cooling/#findComment-4185783
forgets about pump...
Cpu:i5-4690k Gpu:r9 280x with some other things
https://linustechtips.com/topic/307994-new-to-water-cooling/#findComment-4186516
I was thinking the same thing  :lol:
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/307994-new-to-water-cooling/#findComment-4186718
