Do yourself a favor and uninstall that virtual tumor from your PC.
Stick to legacy drivers with Razer products.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/307703-help-please/#findComment-4181220
Link it to a .EXE  path in windows explorer and it will switch profiles to whatever profile you have set to that profile
Example:  A:\Steam Library\steamapps\common\Counter-Strike Global Offensive\csgo.exe
Then Synapse would switch to whatever profile had to setup the link programs with it. the only downside to this is after you quite the program the mouse doesn't switch back.
I also agree with the removal of it. I tried to use it and it didn't go very well.
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/307703-help-please/#findComment-4181288
