Calc 2 help
Go to solution Solved by ilikemacandpc,
Split it into multiple areas that are bounded by only two functions. Make them all as functions of y and integrate with respect to y .
http://tutorial.math.lamar.edu/Classes/CalcI/AreaBetweenCurves.aspx
Look at example 6.
I'm a bit stumped with my calculus 2 homework.
My professor is Russian, with a thick accent. So every few words I have no idea what she is actually saying.
Anyway, I have this problem:
(1 point) Find the area of the plane region enclosed by the graphs of the functions:
2x = y^2, x + y = 4, x + y = 12
I have drawn out the functions and found the region, but I'm not sure where to go from here.
The book provides examples using 2 functions, but I can't find any examples using 3 functions.
Any help would be appreciated.
https://linustechtips.com/topic/307651-calc-2-help/
Ya profs always give you questions with more variables and junk than the book examples use. Can't say I coverted this material in my cal 2 class.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/307651-calc-2-help/#findComment-4180531
Look at example 6.
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
https://linustechtips.com/topic/307651-calc-2-help/#findComment-4180576
Calculate the intersection points.
Integrate sqrt(2x) - the positive red graph- between the two intersection points with positve y-values. Then you subtract the region of a triangle on the left and at one on the right side.
Then you have the region above the x-axis. Calculating the region below goes analog e.g. mirroring the graph.
https://linustechtips.com/topic/307651-calc-2-help/#findComment-4183320
