Help on air cooling (CPU)!
Hi!
Been a long time lurker but I just decided to ask here as I have a doubt regarding a cooler for my CPU. I have the 4690k with stock cooler atm and I just wanted to play with it a little bit (OC) :D
I have been searching for some budget coolers and I came up with these: Raijintek Themis and the Cryorig H7. I was going for the Themis, as it outperforms the Evo 212 but now with the H7 brought back the confusion.
I shall refer that I need such "small" cooler because my case is the Corsair Spec 02 and doesn't have a massive space for cooler height.
Thanks in advance!
https://linustechtips.com/topic/305722-help-on-air-cooling-cpu/
Wow, thanks for the quick replies!
Yeah, I may end up going the H7, just gotta find it. And I'm aware of that Reece, it won't be nothing too extreme though. I should have checked for this before buying the case, shame on me.
I also have a spare Thermalright TY-140 (got one in the case too) that I got from a friend and I think that maybe I could fit it in the cooler. Is this a good idea?
https://linustechtips.com/topic/305722-help-on-air-cooling-cpu/#findComment-4155547
i would use the stock fan to start with and see how that works. if it louder and the ty 140 will fit then you could use that instead.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/305722-help-on-air-cooling-cpu/#findComment-4155566
The TY-140 would be great if you can fit it.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/305722-help-on-air-cooling-cpu/#findComment-4163356
Maybe I can fit both, one as blow and one as push?
It's called push/pull and you can probably do that especially if you have the TY-140 pulling from the side without the ram.
https://linustechtips.com/topic/305722-help-on-air-cooling-cpu/#findComment-4179052
Yes, push/pull, sorry,don't know why I wrote blow, lol.
Yeah, I'll try the different configs. Maybe I can put both TY-140 on the cooler and the stock cooler one in the front of the case.
Btw, i bought a PWM Y splitter but one end only has 3 pins. If I stand correct, one will be using the PWM feature but the one with the 3pin will be always working at full speed? Is this correct?
https://linustechtips.com/topic/305722-help-on-air-cooling-cpu/#findComment-4181158
Pwm is used with 4pin connectors. You should be able to control the fan speeds depending on the motherboard if you connect them to it.
https://linustechtips.com/topic/305722-help-on-air-cooling-cpu/#findComment-4183089
This one is a "bit" more expensive but is it worth the price difference?
http://www.thermalright.com/html/products/cpu_cooler/macho120_reva.html?panel=1
https://linustechtips.com/topic/305722-help-on-air-cooling-cpu/#findComment-4198010
It depends on how much more expensive it is. There's been no mention of pricing.
https://linustechtips.com/topic/305722-help-on-air-cooling-cpu/#findComment-4215248
That Thermalright is 40-45€. The H7 is around 30€, I think as it is not in stores yet.
Sorry for the late reply--the thread was buried under some tabs in my phone.
The H7 is the better value if you can wait for it to go on sale.
https://linustechtips.com/topic/305722-help-on-air-cooling-cpu/#findComment-4284932
  • 4 weeks later...
The cooler finally arrived in my country for a price of 37€. Now there's something, i may have a deal of a second hand Noctua NHU12P with the socket 1150 adapter for 25€. Is it worth over the H7?
https://linustechtips.com/topic/305722-help-on-air-cooling-cpu/#findComment-4505418
The u12p performs a bit worse but is quieter--up to you what is most important.
https://linustechtips.com/topic/305722-help-on-air-cooling-cpu/#findComment-4506428
