Hi guys, im looking for a case to replace my bitfenix neos for under $70 and i was wondering if this is a good choice : http://www.amazon.com/Sentey®-Gs-6020-Computer-Removable-Aluminum/dp/B00BW4O4A0/ref=sr_1_165?s=pc&ie=UTF8&qid=1423084201&sr=1-165&keywords=window
recommendations are helpful preferably with a side window.
https://linustechtips.com/topic/305677-case-opinions/
ehhh i would spend a little more and get a s340 from nzxt only 4.99 more
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/305677-case-opinions/#findComment-4154994
