So I don't know how to use the bios overclocking because it simply will not give me options. when I use msi command center It crashes and says windows something  and I don't know what to do. I have no Idea how to work with the msi bios because there are no video on youtube with it. I have attached a screen shot with the setting on the cpu part of my oc tab.(sorry for it being upside down)
post-116502-0-69033400-1423260701_thumb.
https://linustechtips.com/topic/305673-overclocking-help/
Here's a 4.4GHz overclock guide (pretty basic stuff here):
First things to change in the Bios. Make sure you are on your newest bios before overclocking.
1. Set "All Core" CPU Multiplier to 44X
2. Set CPU cache Multiplier also called the Ring bus multiplier to 35
3. Set Fixed CPU Vcore to 1.25 -1.30v
4. Set CPU Cache Voltage also could be called Ring Bus voltage to 1.20v -1.25vv
5. Set Vrin also called "CPU Input Voltage" To 1.9v - 2.1v
DO NOT and i repeat DO NOT mix up the "Cpu Voltage" and the "CPU Input Voltage". One is for the CPU and the other for the On Die VRM's.
Save and reboot into windows.
Use your favorite Stress tool. I used IBT on High and monitor temps with Realtemp or some other monitoring program.
Run it for 10 Runs or 20 or whoever you feel comfortable with. I run it for 10 usually. If it doesn't blue screen you after the 5th run you could assume you're stable. Again run it for as many times as you want. Get through 10 or 20 runs and no crash? Congratulations you're stable and you can fine tune.
Some extra's. Some bios' will add in a little offset voltage for both the CPU and Cache. Mine was .8 for the CPU and .4 for the Cache. If that happens put the lowest setting you can. Not "Auto" but .01 for each. My ASRock board did but i don't know if yours will.
Also fixed your picture for anyone who cares to chime in:
https://linustechtips.com/topic/305673-overclocking-help/#findComment-4155114
1) turn your monitor the right way up
2) set Dram frequency to xmp
3)what cooler do you have?
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/305673-overclocking-help/#findComment-4155140
my problem is that it won't let me change those settings
+/- on the keyboard to change them. use a usb 2.0 port or a ps2 keyboard
Rig Specs:
https://linustechtips.com/topic/305673-overclocking-help/#findComment-4155287
No  I Can't change the core ratio and stuff like that
can you type in numbers?
Rig Specs:
https://linustechtips.com/topic/305673-overclocking-help/#findComment-4155379
and how do I do that
read the motherboard manual. it tells you in there
Rig Specs:
https://linustechtips.com/topic/305673-overclocking-help/#findComment-4155454
