Razer Naga 2014 Issue
These past few weeks, my Naga has been disconnecting from my PC at random and the functions I've set to it will not actually change back to what I had set it to with the profile in Synapse (meaning even though I switch between profiles, some functions continue to not actually work).
I've downloaded all updates for Synapse when this started - I never download it's updates unless I'm personally experiencing issues or if there's a functionality update.
Physically unplugging the mouse and plugging it back in does not solve the issue.
I can probably try another USB port to see what happens after a while; the mouse is the only device randomly disconnecting so it could be a failing port?
If anyone has had a similar issue I'd like to hear from you.
https://linustechtips.com/topic/304791-razer-naga-2014-issue/
I would try a different port first and report back to us with your findings.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/304791-razer-naga-2014-issue/#findComment-4142399
Give another USB port a shot first, then afterwards if it continues give it a try with a laptop or different desktop if your able to and see if it happens, If it continues I would replace it.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/304791-razer-naga-2014-issue/#findComment-4142409
This /\ /\ /\ /\ /\
https://linustechtips.com/topic/304791-razer-naga-2014-issue/#findComment-4142414
