Hello everyone!
I am planning on upgrading my rig. It will be upgraded to the following parts -
PCPartPicker part list: http://pcpartpicker.com/p/4wMPcf
Price breakdown by merchant: http://pcpartpicker....cf/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($346.50 @ Directron)
Motherboard: Asus RAMPAGE V EXTREME EATX LGA2011-3 Motherboard  ($458.79 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($261.98 @ Newegg)
Case: Corsair 900D ATX Full Tower Case  ($309.99 @ NCIX US)
Total: $1377.26
Generated by PCPartPicker 2015-02-01 15:11 EST-0500
+ The custom loop -
290x Lightning Block from EKWB
EK XTX 480MM Radiator
EK Tubing
EK Pre-mix red
Swiftech MCP655 PWM
EK X3 400 Reservior
EK Elite Intel block
This is Primarily gaming and a few editing for friends channels.
I love the Rampage v extreme and yeah. Plus I will have buy  intel overclocking protection   :)
Would you change anything here?
Thanks!
Note current specs in sig and all parts that can be reused will be reused
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/304525-extreme-build-upgrade/
You picked some great parts there! I personally wouldnt change anything lol & can't really comment on the watercooling as I dont have a custom loop :( (yet! :o)
Edit: get 4x4GB Corsair DDR4 instead of 2x 8GB!
There have been reports of people having issues with combining different DDR4 kits(2 kits of the same manufacturer bought seperately)
        »»» Frankz' X99 System «««
CPU: 5820k 4.6Ghz 1.31v, Motherboard: Asus Rampage V Extreme, RAM: G.Skill Ripjaws4 16GB DDR4@3000Mhz, GPU: ASUS GTX780 DirectCUII
         SSD: Samsung 850 EVO 250GB, HDD: WD Blue 1TB, PSU: EVGA SuperNova 850 G2, Cooler: Corsair H105, Case: Corsair Obsidian 750D
https://linustechtips.com/topic/304525-extreme-build-upgrade/#findComment-4138816
Huh K, will look into it. Also do you recommend the Rampage V Extreme?
https://linustechtips.com/topic/304525-extreme-build-upgrade/#findComment-4138841
Do you have / need a 1080p or 1440p? Peripherals? Windows?
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/304525-extreme-build-upgrade/#findComment-4138857
Yea I totally do, I don't regret for a second going for the R5E. If you're into overclocking you're gonna love it lol.
Reason why I mentioned the RAM thing, seeing as you took 2x 8GB, I assumed you would add more ram later & I'm just trying to save you from any potential issues that could come from that :P
https://linustechtips.com/topic/304525-extreme-build-upgrade/#findComment-4138891
:D You missed a line - Note current specs in sig and all parts that can be reused will be reused
I Have a VG248QE and all pheripherals and windows
https://linustechtips.com/topic/304525-extreme-build-upgrade/#findComment-4138940
Well, I suppose you won't want a better monitor... (1440p).
Anyway, the main change: get rid of that Corsair RAM, and go for this. It's cheaper, it's faster, and it's red (to match the theme). It can't get any better.
https://linustechtips.com/topic/304525-extreme-build-upgrade/#findComment-4139023
Its faster? Um I dont think so. Basically Speed divided by latency = Actual Speed
So for ADATA - 2800/17 = 161
And Corsair got 171.
I have had bad experiance with Kingston and HyperX and then found Corsair. Currently using my 3 set of corsair ram and it works great.
Have you used ADATA?
https://linustechtips.com/topic/304525-extreme-build-upgrade/#findComment-4139037
I would advise against 2800mhz ram in general. When using xmp it'll use the 125 strap and put the bclk at 127. Which some ppl have found an annoying bclk to work with when overclocking their system.
https://linustechtips.com/topic/304525-extreme-build-upgrade/#findComment-4139083
