so i just bought a gtx 750ti to put in my old dell precision 490 with a 750w psu and 2 xeon 5160 cpus but when i installed it, it never worked so i called evga support and they told me since my mobo is so old that the maxewell gpus will not work on it not to mention its pci gen 1 so he recommended a Kepler gpu or older so i was wondering if an r7 260x will work or a gtx 650ti
Why can't a Cleric/Priest/Bishop help a beginner KoC? Cause he's No-bless...When I post something, the thread dies.OR I'm incredibly good at giving informations,
OR I'm a thread killer.
Prolly both.
https://linustechtips.com/topic/304240-need-help-finding-a-gpu/
No..... just no, get a new cpu and mobo
would if i had the money
Prolly both.
https://linustechtips.com/topic/304240-need-help-finding-a-gpu/#findComment-4134715
the smartest thing in this scenario is to go and pick up a new motherboard from Asus,MSI,Gigabyte, Asrock etc and maybe pick up an i3,i5,i7 (depending on what budget you're on) There's no need to return the graphics card and if your motherboard only supports PCI-E 1.0 you should probably upgrade
https://linustechtips.com/topic/304240-need-help-finding-a-gpu/#findComment-4134732
as i have said i would if i had the money a dell precision 490 is only compatible with dell precision 490 parts so if i had to replace mobo i would have to build a whole new pc
Prolly both.
https://linustechtips.com/topic/304240-need-help-finding-a-gpu/#findComment-4134776
Why isn't any one helping this guy by answering his questions?    He's on a budget and there's nothing wrong with that.   "Spend even more money and upgrade the rest of your stuff" isn't ideal for some people for a number of potential reasons.
@BUREIDEN I wish I could give you some advice about some specific cards as options.  What you might try doing is posting in the Video Card forum.  But leave off the details about why you need an old card (just ask about Kepler cards) and hope that no one from this thread infects that new thread with worthless posts, too.
https://linustechtips.com/topic/304240-need-help-finding-a-gpu/#findComment-4135458
go pick up a like a used 580, theyre beastly :D
Just not a 590... god do you remember the issues with that card?
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/304240-need-help-finding-a-gpu/#findComment-4135482
or the issues with every single dual gpu cad that has ever been made :S
the only good one ive heard of is the 760 Mars
https://linustechtips.com/topic/304240-need-help-finding-a-gpu/#findComment-4135986
I had a 6990 + 6970 trifire rig and that was good, if you can handle the noise and heat.
https://linustechtips.com/topic/304240-need-help-finding-a-gpu/#findComment-4135989
but i cant :S my single 770 is more than enough noise lol, cant wait to water cool it
https://linustechtips.com/topic/304240-need-help-finding-a-gpu/#findComment-4136015
Oh I was just saying for the purposes of discussion lol.
And also OP, it may be time to upgrade system rather than GPU.
https://linustechtips.com/topic/304240-need-help-finding-a-gpu/#findComment-4136029
Yeah, get a 580
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
https://linustechtips.com/topic/304240-need-help-finding-a-gpu/#findComment-4136474
Dual 760s is a joke. I would have liked Dual 780s or 770s
But i would like to see a dual card from Asus with dual 980s due to their low TDP
https://linustechtips.com/topic/304240-need-help-finding-a-gpu/#findComment-4136482
