Fan Cable Reduction
Go to solution Solved by Archangel1994,
Is there a suggestion you have for a different set of fans? (Also) Thank you thats what i was thinking but i wanted to make sure that i would not run into reductions issues from the wiring of the extensions(like you do with normal wires)
1. Tell him not to do push pull, it's 100% redundant
2. Gentle Typhoons, Phobya Eloops, NF-F12's, Noiseblocker PK2/3
Hey Everyone,
So i am in the planning stage of a build for a friend, and ive come across an issue ive never had before. My friend wants to put a total of 26 Corsair SP 120 High performance fans in his build,
2x480mm
1x360mm
1x240mm
All in push pull,
So my question is this how many Y-Cables can you use to reduce the size down to a reasonable fan controller and not  run into power issues?
https://linustechtips.com/topic/304153-fan-cable-reduction/
1. 26 fans is stupid
2. Push/pull is pointless
3. Tell him to not get SP120's
4. A fan controller often has 15-30W per channel so you need to look how much each fan uses to determine the mount of fans you can put on 1 channel
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/304153-fan-cable-reduction/#findComment-4133343
Hey Everyone,
2x480mm
1x360mm
1x240mm
All in push pull,
Motherboard headers usually have enough current to power 3 Fans without problem. If you're hooking them up to a fan controller you'll have to look at the specs of that controller and the specs of the fans.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/304153-fan-cable-reduction/#findComment-4133360
Thanks yeah, he is not wanting to use the onboard fan positions, ill try and convince him to cut down the number so we can make this a little easier.
We Need MOAR FANS !!!
Yeah this was epic and stupid,
https://linustechtips.com/topic/304153-fan-cable-reduction/#findComment-4133459
https://linustechtips.com/topic/304153-fan-cable-reduction/#findComment-4133500
