Alright so I'm looking to upgrade my rig but need help. What what give me mire performance two msi r9 290x lightning, 7990 or wait for the new range my budget is £600 what would you suggest?
Laptop Macbook Pro 15" 2018 With Touchbar
CPU  AMD Threadripper 1950X Motherboard Asus Zenith Extreme Ram G.Skill Trident Z RGB 64GB (8x8GB) DDR4 3200MHz GPUs 2X MSI 1080TI Seahawk X  Case Cooler Master Cosmos C700P Storage  Corsair NX 400GB Pcie SSD / Samsung 850 Evo 1TB / WD 4TB HDD(W/Optane) PSU Evga SuperNova G2 1600W Cooling  EK Phoenix TR4  Keyboard Corsair Vengance K95 Rgb Cherry MX Blue Mouse  Logitech G502 Lightspeed W/ Powerplay Sounds Corsair SP 2500 / Beyerdynamic DT990 / Schiit Stack  Display  2X Acer Predator X34p 3440X1440
https://linustechtips.com/topic/304101-graphics-help/
wait.... but that would always be my advice. the computer you just brought is already outclassed by what is coming to the showroom by post.
Do you need to upgrade?. do you want amd?
At the moment the beast of a card in that price range is still the 970 despite all it's bad press. If you don't mind waiting check out the 390s
https://linustechtips.com/topic/304101-graphics-help/#findComment-4132638
hey there, welcome to the forums :)
Well only two 290xs will give performance equal to two 290xs :P the 290xs are probably the best value option atm :)
970 are an option, but slightly more expensive, not bad one though.
What resolution are you playing at?
Bleigh!  Ever hear of AC series?
https://linustechtips.com/topic/304101-graphics-help/#findComment-4132644
what resolution are you playing at? at 1080p 2 290xs would be a waste. getting 250fps in everything isn't a benefit to anyone lol.
they'd make sense for 1440p and 4k though
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
https://linustechtips.com/topic/304101-graphics-help/#findComment-4132716
I'll be running in 4k for those asking
Thanks for all the answers
https://linustechtips.com/topic/304101-graphics-help/#findComment-4132810
if you're running in 4k then the only option close to this price range is dual 290x
It gets it's arse kicked on lower resolutions, but the extra frame buffer evens things up at 4k
https://linustechtips.com/topic/304101-graphics-help/#findComment-4132891
Hypocrite.
 lol, not really I game at 1080p on a 42 inch 200hz tv. My single 980 is overkill for that. it's also either out of this price range or right on the limit.
I'm planning on a second 980. but that's an extra 800 AUD
A the 500 buck USD price range a couple of 290x in crossfire will beat a single 980 at 4k res. (They'll have difficulty beating the card at anything lower.)
https://linustechtips.com/topic/304101-graphics-help/#findComment-4133025
for 4k I'd go r9 295x2.. yeah its just 2 290xs buy it looks awesome, comes water-cooled and just sounds better lol
https://linustechtips.com/topic/304101-graphics-help/#findComment-4133033
