High Cpu usage + Static audio
By
boomboomtucki
in Troubleshooting
in Troubleshooting
Solved by sof006,
Does anyone have a solution?
Get a sound card, my PC does this also and the sound chip is significantly better than yours. The only way to avoid such interference is to get a sound card. I bought a cheap one that has extraordinarily good sound for £20, put it in my machine. No funny sounds anymore. Just make sure its compatible with your PCI slots.
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
