Case: CoolerMaster HAF X
motherboard: ASUS Sabertooth 990FX/3GEN R2.0
CPU: AMD FX 8350 4.0GHZ
SSD: Samsung 840 Basic 120GB
GPU: XFX Radeon HD7990 6GB
PSU: Chieftec Nitro 88 1000 W
RAM: Kingston HyperX Predator 16GB 2133MHz
CPU cooler: cooler: CoolerMaster Seidon 120M
Case fan:  CoolerMaster Mega Flow red 200mm
i want to know its everthing fits.
CPU and mobo have same socket(am3+)
and will this be a great gaming rig?
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/30344-will-this-system-work-together/
Heya,
The HAF-X is quite a big case in terms of ATX based case systems. So it will be big enough to accommodate all the components  ^_^ .
Seems like a good choice of components but you could get away with a smaller sized PSU. Somewhere in the 800 watts range 80+ gold would be the sweet spot.
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
replace the 1000 wat for this
XFX XXX Edition 850W 80+ Bronze
i already changed it but i forget to write in the new one:D
is radeon HD 7990 a good choice?
It is a good card. It is essentially 2 x 7970s a little higher clocked but slightly lower clocked than the 7970 GHz edition which is a premium overclocked card. It has 6GB vRAM which is great for eyefinity (multiple displays 3 or 5 displays)
Elven
why U buy a 7990? i would spend the money on 2 780 or a titan ;D
i7 4790K@4.5GHz-1.15V, BeQuiet! SR2, Asrock z97e-itx/ac, Kingston  Fury 16GB@1866MHz, GTX 670 2GB, 3x ssdNOW300V 300ishGB, Bitfenix Prodigy, OCZ ZT 750W Twittwit@enRodjavel
