I/O shield Installation
Go to solution Solved by MattTheMayor,
Unfortunately, I cut the metal pins off my I/O Shield.
I try  :(
Here's a picture I found on the internet that is similar to my problem.
oh lol those. before fully installing in my motherboard, i make sure to slide them down so it won't block.
Okay. I've have currently build 2 computers. One for a friend and one for myself but something both system have in common is that both the I/O shield seems to be installed wrong. What do I mean? I mean that the metal pins seem to be sticking out. Some of them blocks the port making them really hard to use.
My question is how am I suppose to correctly install it?
I'm about to do a $3000 build for a friend and I don't want to screw it up T_T
| i7 4790k | H100i | 16GB (8x2) Corsair Vengence | EVGA GTX 780 SC | ASUS Z97 Sabertooth Mark I | Samsung 840 120GB | WD 2TB Green x2 | Rosewill Hive 750W |
https://linustechtips.com/topic/303407-io-shield-installation/
can you provide a picture?
You literally push it in from inside the case
I try  :(
Edited by IvanSnipedYu
https://linustechtips.com/topic/303407-io-shield-installation/#findComment-4123090
I try  :(
https://linustechtips.com/topic/303407-io-shield-installation/#findComment-4123124
Okay, I'm going to listen to your advice. If I ruin his Z97 Sabertooth Mark I, I'm blaming you LOL!
https://linustechtips.com/topic/303407-io-shield-installation/#findComment-4123150
Just keep an eye on that thing when you put the motherboard, and make sure you don't cut yourself with the damn I/O shield lol.
The stars died for you to be here today.
A locked bathroom in the right place can make all the difference in the world.
https://linustechtips.com/topic/303407-io-shield-installation/#findComment-4123268
