When it comes down to it, case will affect FPS by like 1-2 in the absolute worst case scenario. Just look for the one with the features that YOU need (Whether that is USB 3.0 ports, drive cage location. etc...) and the one that is cheapest that has all of them, and most importantly looks the best.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/303389-need-help-picking-a-case/#findComment-4122908
The 450d is probs your best bet, however the N600 has a lot of functionality
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/303389-need-help-picking-a-case/#findComment-4122925
I really like the n600 and I'm still using it. If you live in a dusty area or your computer is on the floor/carpet it's a dust magnet.
Everything else is amazing about it but keep that in mind.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/303389-need-help-picking-a-case/#findComment-4122928
The 450D has fantastic airflow and cooling capabilities, especially when you max out on case fans.  Looks good with LED front fans if you're into that sort of thing.  Cable management is a little bit lacking, it could use a couple of extra cable tie points and a routing hole for front panel audio, but you can definitely work around those with some decent cable management.  Overall I'm very happy with mine.
That being said I probably would have opted for an NZXT H440 if I didn't need an optical drive (ended up 'stealth modding' mine to keep the clean aesthetic of the case).
Pic here if you're interested: http://linustechtips.com/main/topic/183-show-off-your-setup/page-449#entry4052500
CPU Intel Core i7 7700K; Cooler Cryorig R1 Universal; MB Asus ROG Maximus IX Code; RAM G.Skill Trident Z 3200Mhz (4 x 8GB); GPU ASUS GTX 1080 Ti ROG Strix Gaming OC; Case Be Quiet Dark Base 900 Pro Silver; Storage Samsung 960 EVO 500GB, Samsung 850 EVO 1TB, Seagate Barracuda 4TB; PSU EVGA Supernova 850W G2; OS Windows 10; KB Corsair K70 (MX Brown); Audio O2 & ODAC, Sennheiser HD 600, Sennheiser RS 185, Swan M200MKIII; Monitors 2x Dell U2410
Previous Build
CPU Intel Core i5 4690K; Cooler Cooler Master Hyper 212X; MB Asus Z97-A; RAM G.Skill Sniper (2 x 4GB); GPU 2x Gigabyte GeForce GTX 970 G1 Gaming (SLI); Case Corsair Obsidian 450D; Storage Samsung 840 EVO 120GB, WD Black 1TB, Hitachi 750GB; PSU EVGA Supernova 750W G2; OS Windows 10;
https://linustechtips.com/topic/303389-need-help-picking-a-case/#findComment-4122969
Tyvm his/her build is pretty much same as mine! :) I'm choose ing the 450D
https://linustechtips.com/topic/303389-need-help-picking-a-case/#findComment-4123030
Pic here if you're interested: http://linustechtips.com/main/topic/183-show-off-your-setup/page-449#entry4052500[/quote/]
What colour LEDs u think I should pick? I'm thinking green how bout you?
https://linustechtips.com/topic/303389-need-help-picking-a-case/#findComment-4123088
It's up to you really.  I matched my fans to the LED on the GPU.  If Zotac 970s were easier to get where I live, I might have gone with red.   If you're using a card with the Titan/980 style reference cooler, matching green LED fans might be a good choice.
Previous Build
https://linustechtips.com/topic/303389-need-help-picking-a-case/#findComment-4123791
It gonna be black n red inside n black case green prob make it cool or red
https://linustechtips.com/topic/303389-need-help-picking-a-case/#findComment-4124458
