Multiple audio sources for one headphone?
fredghostkyle
Hi, While I'm an avid PC gamer, GTA V and Halo are still not available for PC so I have an Xbox 360. But I'd rather listen to Skype and Pandora from my computer but still want to hear the game's audio as well. Is there any way I can have multiple inputs then one/two outs? Like a sound board.
~FRED
Obligatory PC specs
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Corsair H50
Motherboard: Asus Z170-E ATX LGA1151
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB)
Storage: ADATA Premier SP550 240GB
Storage: Western Digital Blue 500GB
Storage: Western Digital BLACK SERIES 1TB
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1
Case: Fractal Design Define S
Power Supply: Corsair CSM 550W
If you are new please read the CoC!
 Please FOLLOW YOUR OWN THREADS!
 Quote people when replying to them.
PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR DARK THEME USERS.
 Mark your problem as solved if answered and like all helpful information.
 DO NOT QUOTE IMAGES(!) just type -pic- or tag them as spoiler.
Don't criticize people for asking "stupid question".
There is actually a hidden search feature on the forums here: Search
IT DOESN'T MATTER IF YOU'RE A FANBOY/FANGIRL. WHAT MATTERS IS THAT YOU DON'T LET THAT EFFECT YOUR HARDWARE RECOMMENDATIONS.
DO NOT POST SPAM!
Plug the audio out of the console to line in jack of the PC. The PC's onboard/soundcard will do the mixing for you. Just make sure the console can output analog audio signal. If it can't, then you'd need a DAC in between to convert it to analog signal first. This is because PC's line in only accepts analog signals.
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
Obligatory PC specs
DO NOT POST SPAM!
That is a multi out.  He wants a multi in
you can plug in another source with an aux cable and it cross fades all sounds
i have it, i should know
Okay
Obligatory PC specs
DO NOT POST SPAM!
Can't you have Skype and/or Pandora on in the background on the Xbox One?
I think that's the problem - the new consoles only have HDMI and optical outputs. With the controller headset adapter, would work fine, but then you'd have a jumble of cables going to and fro' the controller.
Yes, but that's not proper. Works in a pinch, but not recommended for long term use.
I heard doing this is bad for you headphones is that true? @ShearMe
CPU i5-4690k Motherboard asrock h97-ac RAM 2x4 Crucial Sport GPU Msi 4g gtx 970 Case Silverstone sg13b-q Storage western digital scorpio black 500gb PSU csm 450w Display(s) acerh27hl bmid Cooling intel stock cooler Yeah I know right Keyboard I'd rather not say Mouse logitech g602 Sound beyerdynamic dt990pro Operating System windows 8.1
I can get console out to anything, trust me. Turtle Beach has taught me that.
How could this be bad for you headphones? Listen to any music? They usually have 5 different loops or recordings of music (take a look at any music software, loops get layers on top of each other for the desired effect). I can see no reason for this to be bad for your headphones (and truth be told, I would not care :P ).
~FRED
  • 3 months later...
This is a very bad solution because as soon as you plug a second source(input) the sound is lowered dramatically.
So I decided to look for another solution like a mixer and I would like one that is USB powered and I found this one. It's overkill for what I want to do but I can't really find anything else that is USB powered.
