Does anyone know a good optical drive (DVD/CD Writer) like the http://ca.pcpartpicker.com/part/asus-optical-drive-drw24b1stblkbas but that has the style of the Corsair Air 540(Mid-Tower, Black)? You know, something without that plastic'ish' look of this Asus Optical Drive? Here's what I mean...   http://i.imgur.com/omEcG5z.jpg
I want something that looks more like the finish/style of the Corsair Air 540... kinda more robust looking if you know what I mean?... something that makes more sense when you look at it. I want something in the 10~50$ price range.
Thanks.  :blink:  :blink:  :blink:
https://linustechtips.com/topic/303071-specific-optical-drive/
Stuff. Why can't you just answer my question other than telling me I don't need one? Ffs.
Actually he is kinda right. Any hardware that contains drivers on CD's are usually better off being downloaded from the manufacturers website. OS's are far easier to install using a USB stick (although you will need a second computer to download the ISO and make the USB drive bootable).
Not saying optical drives aren't handy, but you'd be surprised how far you can get without one. In your circumstance I would recommend buying any crappy optical drive but only install it in the case when you actually need it. That's the cheap and cheerful way. :)
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
https://linustechtips.com/topic/303071-specific-optical-drive/#findComment-4118856
