I have a HP Probook 470. It's happened just a few times recently, that when the notebook was on battery, it has completely shut down.
I assume it's something either with the battery or motherboard.  Happens with the 'familiar' subtle crack noise - when you cut power.
Has anybody got some experience with this? It might not be a reason to go straight to service with the notebook, but it could be quite a serious issue.
https://linustechtips.com/topic/302946-notebook-power-cut/
this problem is associated with the power supply circuit board in the laptop
normal user cannot fix this problem
so sent it to HP for repairs
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/302946-notebook-power-cut/#findComment-4122182
ok, thanks.
Do you have any idea why this happens? Is it simply with time?
time and luck
my acer laptop which i use as normal have a dead GPU
https://linustechtips.com/topic/302946-notebook-power-cut/#findComment-4125824
