Will the NZXT Kraken X61 fit inside Fractal Design Define R4? I know it supports 280mm coolers, but people are saying that there are clearence issues with motherboard heatsinks. My mobo is Asus M5A97 R2.0.
CPU: AMD FX-8320 4.3 GHz | CPU Cooler: Cooler Master Hyper 212 EVO | Motherboard: ASUS M5A97 R2.0 | RAM: Kingston HyperX 1600 MHz 8 GB | GPU: Sapphire Radeon R9 280X Vapor-X 3 GB OC | SSD: Samsung 840 EVO 120 GB | HDD: Hitachi Deskstar 500 GB 7200 RPM | PSU: EVGA SuperNOVA NEX650G 650 W | Case: Fractal Design Define R4 Titanium Grey Windowed | Monitor: LG IPS237 LED IPS
https://linustechtips.com/topic/302944-will-it-fit/
you culd mod it to fit but PLEASE look up the manufactureres website
oficially supports "some models of 240rads, depending on configuration"
8!!!!! seconds until i got there!!!!!
google is not THAT hard
you an cut the 5.25" bay to fit a 280 in the front but thats quite difficult if you re not used to stuff like this and you culd ruin your case
Main Rig:
CPU: i7-2600k @4.8 GHz - CPU cooler: bequiet! Dark Rock Pro Motherboard: ASUS P8P67 Deluxe GPU: Gigabyte GTX 970 G1 Gaming SSD: Samsung 840 EVO 250GB - HDD: Western Digital Green 1tb - PSU: EVGA SuperNova G2 750W - Case: Fractal Design Arc Midi r2 -
Obsidian 250D Build Log
Wisdom: You don't live longer if you're always in a hurry
https://linustechtips.com/topic/302944-will-it-fit/#findComment-4116763
I don't think it does. Where have you heard this? I don't think the x61 will fit :/
Well it has 2 140mm fan positions on top so I assume it should support 280mm radiators.
https://linustechtips.com/topic/302944-will-it-fit/#findComment-4116778
I'm definetly not going to mod my case, but it has 2 140mm fan positions on top and the only problem I see is the space between the mobo and the cooler.
https://linustechtips.com/topic/302944-will-it-fit/#findComment-4116796
Ah well, on the R4 page it says:
"Top: 2 - 120/140mm fans (not included) - positions also support some models of 240 radiators, depending on configuration"
However, they have answered your question before:
https://support.fractal-design.com/support/articles/138156-define-r4-what-size-radiator-will-fit-in-the-top-panel-
So in answer to your question, no an NZXT X61 (or any 280mm radiator) will not fit. :/
https://linustechtips.com/topic/302944-will-it-fit/#findComment-4116803
http://www.overclock3d.net/reviews/cases_cooling/fractal_designs_r4_review/1
But here says it can support 280mm radiators. I'm so confused.
https://linustechtips.com/topic/302944-will-it-fit/#findComment-4116835
Oh yeah, that is confusing. It's up to you, but I'd go with this one ( https://support.fractal-design.com/support/articles/138156-define-r4-what-size-radiator-will-fit-in-the-top-panel ) because that's an official reply from Fractal Design, not much more we can do unless someone who actually tries it replies.
https://linustechtips.com/topic/302944-will-it-fit/#findComment-4116884
Yeah, I will do some more diggin before buying and i hope someone who owns this case and tried mounting a 280mm rad replies to this thread.
https://linustechtips.com/topic/302944-will-it-fit/#findComment-4116914
Yep I'm also checking wether my 240mm rad( deepcool maelstrom) will fit at a define r4 D:<
i5 4690k @ 3.5Ghz | Stock Cooler :/ | ECS Gank Machine Z87H3-A2X EXTREME | Gskill RipjawsX 8GB 1600Mhz | MSI GTX 960 100th ME 2GB | Samsung 840 Evo 120GB | 1TB WD Caviar Blue | Seasonic m12ii evo 750W | Razer Modded Phantom 410
https://linustechtips.com/topic/302944-will-it-fit/#findComment-4116936
This cooler should fit IMO.
https://linustechtips.com/topic/302944-will-it-fit/#findComment-4117008
