Xonar Essence STX is a great card.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/302815-looking-for-sound-card/#findComment-4114871
in my opinion, sound cards are pretty much useless unless you have beefy headphones. your computer's integrated sound should do fine.
actually they're useless for those too.
a dedicated dac and amp serve much better in those situations.
https://linustechtips.com/topic/302815-looking-for-sound-card/#findComment-4114877
A good sound card is not the only one contributing to a good sound experience.Headphoes are also a big part of this experience.Since you will listen to music i would recommend buying a dack for headphones.Why?Well you can find a good dack from 150$ and you will still have enough money to buy a decent set of headphones to go along with it.Most decent sound cards will cost a lot and they are not meant for headphones but for 5.1 and 7.1 systems.Considering you have a 5.1 or 7.1 a sound card will be around 30% of the sound quality you have on the output.Most modern speakers have their own presets,encoding,sound signature and so on.As for the card to recommend well...ASUS Xonar D2/Essence STX/st
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/302815-looking-for-sound-card/#findComment-4114898
the sound card will plug in directly to my   Audioengine A5+ speakers
You don't need a soundcard then.
And it's not always sunshine every morning. But it's safe to make that assumption and is generally true.
You said it as an absolute, and it's not true all the time.
https://linustechtips.com/topic/302815-looking-for-sound-card/#findComment-4114932
