Virus Removal! HELP!
Go to solution Solved by nj4ck,
try booting in safe mode. Then run over it with your antivirus, malwarebytes and whatever else it takes.
Hello people of LTT Forums,
I recently kicked off my programming channel, and I wanted to find a free screen recorder. I installed CamStudio, and now I regret it. This was last night, by the way. After installing, two new programs, called Super Optimizer and Vosteran appeared on my desktop. I tried removing them last night by deleting their folders and moving them to the trash, however when I booted this morning, after going to the login screen, I am greeted with both my monitors being black screened, my cursor, and a super optimizer window. I cancel the operation, and then I'm just left with two black screened monitors and a cursor. I've already tried plugging them back in.
I have a SATA power and data to USB cable that I can use with one of my macs to remove the file, but do ANY of you guys have ANY idea how to remove this? I don't want to pay a shit ton of money, much less any at all. Help would be really appreciated, quickly preferably.
Thanks,
Jake
PC SETUP: | i5-4440 3.1 GHz | MSI Z97s Krait | EVGA GTX 970 | G.Skill Value 8GB | WDC Blue 500GB | NZXT S340
MOBILE SETUP: | Apple iPhone 6 | iOS 10b4 | Apple Watch Stainless Steel w/ Black Sport Band | WatchOS 3b4
Steam: chargerjake | Origin: chargerjake
https://linustechtips.com/topic/302277-virus-removal-help/
Why haven't you uninstalled them ?
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/302277-virus-removal-help/#findComment-4107196
UPDATE: I have booted into safe mode and installed Malwarebytes, which a lot of people have recommended, and I am now running a scan. So far, it has detected about 18 items, 6 of them vosteran, 12 Super Optimizer. Still about 7% through. Anyway guys, thank you.
https://linustechtips.com/topic/302277-virus-removal-help/#findComment-4107250
