Depends on the RAM usage. If the program cannot use enough to peak 16GB then the 16GB kit will be better. However I recommend you get 32GB of 2400MHz ram
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/302023-ram-speed-help/#findComment-4104127
I would buy 2x8 gb sticks of 1866 or 2400 MHz... Then when your ready to upgrade, get two more!
Case: Corsair 760T White PSU: Corsair AX1200i Motherboard: Asus Maximus VII Formula CPU: I7-4790k Cooler: Stock Cooler Ram: Corsair Vengeance 16GB 2400mhz GPU: Asus Strix GTX 970
https://linustechtips.com/topic/302023-ram-speed-help/#findComment-4120572
