I think that the 3.5 GB is the problem, try to clear the cmos.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/301522-no-display-problem/#findComment-4097627
no display problem
So if there is no problem what is there to fix xD /s
Just try another dvi port or maybe hdmi/displayport to see if that is the problem.
MacBook Pro 15' 2018 (Pretty much the only system I use)
https://linustechtips.com/topic/301522-no-display-problem/#findComment-4097727
