Hi guys n' gals, i'm in need of some help/advice!
I'm looking to upgrade my pc, I had purchased a pre-built gaming pc (which was okay at the time) and is now extremely dated. I'm in need of new parts.
let me give you my specs before I go any further.
(not 100% sure on the brands of all parts)
2TB HDD (Seagate)
16GB Ram (DDR3)
AMD Radeon 6670 GPU (2GB DDR3)
Windowsicon1.png 8 64bit
450W PSU (STOCK)
VIBOX Gaming Case
Gigabyte 78LMT-USB3 Motherboard
AMD FX6300 6 CORE CPU (STOCK SPEEDS)
I'm playing on a 60Hz BENQ 1920x1080p monitor.
I would love to just replace my GPU since gaming is my main reason for buying a PC in the first place, however it turns out my pc GPU is so under powered that its getting its power straight from the PCI-E slot in the motherboard! my PSU doesn't even have a 6 or 8 pin connector to power a GPU!.
So basically I want a good powerful GPU that isn't crazy expensive and can give me a constant 60fps at 1080p. (and wont be bottlenecked by my FX6300)
I obviously need a new good power PSU too, to power the card and the rest of my PC.
Any help/suggestions would be Greatly appreciated!.
Thank you.
Jonny
https://linustechtips.com/topic/301232-gpu-help/
Look at getting an Asus 2GB 7770, it's a great card and I love the two I own
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/301232-gpu-help/#findComment-4093707
He obviously reposted because he still needed help..
https://linustechtips.com/topic/301232-gpu-help/#findComment-4093712
You never told us your budget, or where are you buying from.
But I guess something like this would fit, and be a good upgrade:
PCPartPicker part list: http://pcpartpicker.com/p/JNp8jX
Price breakdown by merchant: http://pcpartpicker.com/p/JNp8jX/by_merchant/
Video Card: XFX Radeon R9 280 3GB Double Dissipation Video Card  ($182.99 @ NCIX US)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Amazon)
Total: $242.98
Generated by PCPartPicker 2015-01-30 16:06 EST-0500
https://linustechtips.com/topic/301232-gpu-help/#findComment-4093735
