Problem with leak in system
Go to solution Solved by Spev,
Ok I think it's ok now...not sure what the problem was, maybe it just wasn't tight enough but I made sure everything was super tight. Took it apart, dried it out, and re attached. Looks like it's not leaking now. Going to probably do a 48 hour leak test, was gonna do 24, but I think I'll go with 48 since this happened just to be sure. And my pump finally just is quieting down now :) Crossing fingers everything is ok!
So I finished putting together my loop yesterday...I'm having a problem. Just started my leak test and within 30 seconds I found a leak. The right angle rotary fitting under the GPU is leaking a lot. I tightened it and it has an oring....I'm not sure what the problem is....help? Wtf  :(
post-155082-0-55574000-1422648038_thumb.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/301189-problem-with-leak-in-system/
First, nice loop.
Second, where is it leaking, in between fitting and block or fitting and tubing?
First, nice loop.
It looks like right between the fitting and the GPU. I'm going to try to take it off, dry it off, and put it on again...I tightened it as much I could last night. Maybe I need to get a tool and it was kind of hard to tighten but I thought I did fine. All my other fittings seem ok.
Either theres something wrong with the fitting internally or its not tight enough somehow...
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
SR-2-2x X5650 Xeons-3x 670 FTW-1x 120Gb Force GT-1x 240Gb Force GT-1tb WD Green-12Gb Dom GT 1866-Platimax 1500w-2x HK3-2xD5-24v controller-3x RX 480's-3x NiBlk HK GPU blocks-Koolance tops-BP res-15x SP120's-Little Devil V8.
We all have pressure gauges in our toolboxes, of course :D
Add one,they are less than $10.
You should add one, if you plan on watercooling for the forseable future like myself, tool that that and the pipe bending kits worth $100s are a worthy investment. I'm an ex motorcycle mechanic so I have loads of tools at my disposal and they've paid for themselves plenty of times.  ;)
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
If there are any leaks, they will show up in first 5 minutes. I use UV adds with UV lamp.
You'd better use those pressure gauges to test pipes in plubming, not in such simple systems like wc loop.
Motocycle can take someone's life, so u must be accurate in repairing, u're right.
You're missing the point, B Neg can build a loop and dry test it before filling it which saves him 24hrs worth of leak testing. He can test a loop then confidently just close up his case and use it as is with no issue, so while you put your water in and then leak test it and maul with it for say I dunno a few hours, B Neg is already using the rig before he jumps onto another project.
The pressure guage you speak of in connection with plumbing is quite ironic really too btw, seeing as watercooling is a form of plumbing.  ;)
Chernobyl
Kraken
