URGENT HELP PLS
Go to solution Solved by Tech Lover,
Well, it might be that your removal of that directory screwed up your windows install on the
Laptop C: drive.
Also, is the partition you copied that data to NTFS? And what version of Windows are you running
on your brother's laptop and your own PC?
I have found NTFS to be rather susceptible to filesystem corruption when used as an external
drive, so I would recommend running the chkdsk utility on both partitions of your brother's
laptop drive (https://en.wikipedia.org/wiki/CHKDSK).
Also, if you're running different versions of Windows on the two machines, there might be
issues introduced on that front (http://news.softpedia.com/news/Windows-8-Introduces-New-NTFS-Health-Model-and-chkdsk-268766.shtml).
That's just a guess though, I haven't really familiarized myself too closely with the topic
since I mostly use Linux.
As for your main PC not booting when the laptop drive is plugged in, have you tried going
into the BIOS and force-booting from your Samsung 850? It could be that your PC is confused
by the Windows install on the external drive.
actually what happened was my drive's media was corrupted. because i deleted, unknowingly all the files which had $ before them like $Recyclebin$ and $VolumeLabel$ and i guess 2 more folders like this.
all the files i was transferring were actually being sent to some temporary folder, again with $ before and after the name.
what i did, for any one who might need help, i reformatted the drive using CMD, by loading "Disk Part". the hard drive was not even read. but i kept trying again and again, and booted the system many times so it can be read by the windows and hence CMD did the trick.
its a bit disappointing not many people helped me, although there were many who viewed this thread :(
Alhamdulillah its resolved now.
any how, for those who tried to help. thanks.
hi. i have this laptop of my brother. he asked me to transfer some movies and games from my pc to his. i didnt have a usb 3.0 usb or card reader. i have one of the external hard drives reader from one of my old dead external hard drive from sea gate.
now i removed the laptop hd, connected it with that connector of external hd, i.e, made it an external harddrive kinda, and transfered files to that latptop hd.
now here is the problem. when i connected it back to the laptop closed all the screws and booted the laptop, it didnt show nothing. no files that i took like 3 hours to copy. i removed the screws and removed it from laptop and connected the same way to my computer and all files are there.
in the laptop the drive where i copied all stuff shows the same space of like 90Gb used where when i copied the content to it, it showd like 190Gb used. what to do now? any solution?
sorry for all caps cause my brothers flight is in like 6 hours and he doesnt know shit about pc and these things. help me pls some one what to do?
Current Rig: Intel core i7 4770K Stock 4.5G, Asus Maximus VI Hero, Corsair Vengeance 1600Mhz 16Gb (8Gx2), 2x SLi Gigabyte Geforce GTX 670 2Gb GDDR5 3X Windforce Edition, Corsair Hydro Series H100i (Push), JDS LABS O2/ODAC combo, Fiio E18 KUNLUN, Asus Xonar Essence STX (secondary PC), Sennheiser HD700, Hifiman HE 400i, Beyerdynamics DT 990 PRO 250 Ohm, Sennheiser HD 518, Cooler Master Silent Pro M2 850W 80+, Cooler Master CM 690 II Advanced, Samsun4g DVD R/W Combo, 3X Cooler Master 120mm Blue LED fans, LG IPS 23EA73, Logitech G710 BLUE, BlackWidow Ultimate 2013 Edition,Logitech G402 HYPERION FURY, Bloody Core V7, SteelSeries QcK Mass MiBR mouse pad
https://linustechtips.com/topic/300263-urgent-help-pls/
sorry for all caps cause my brothers flight is in like 6 hours and he doesnt know shit about pc and these things. help me pls some one what to do?are
are you sure they were in the same partition ?
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/300263-urgent-help-pls/#findComment-4078373
When you say it showed nothing, did it not boot? or did the files you copied over not appear? do you get any error messages? and are they in the same partition?
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/300263-urgent-help-pls/#findComment-4078374
i copied all of the files to the drive E on the laptop hard drive. when i connect it to pc it shows, over 190Gb space used and all files show as normal. when i connect to the laptop it is showing only 80Gb used and files are not there. and yes it boots just normal and no problem with that only files missing. also space showing abnormal because the fiels are there,
https://linustechtips.com/topic/300263-urgent-help-pls/#findComment-4078389
can you make sure you go to windows manager and see if you have any partition that isn't mapped on your laptop  ?
PCPartPicker
https://linustechtips.com/topic/300263-urgent-help-pls/#findComment-4078409
i think u are not understanding.
the laptop drive has 2 only 2 partitions. its a 500Gb hard drive. the C drive and E drive.
e drive had like only 80Gb of data in it and rest was like 200 Gb available space BEFORE EVERYTHING.
i removed it from latpop, connected it via a seagate external hard drive connector and used its USB 3 cable to connect to pc and transfered some 150Gb of data to it.
then i removed it from that connector and installed it back to the laptop. the laptop booted just normal and fine and showed the same 2 drives, C and E.
now the space should have been decreased in E cause of the new data of 150Gb i put into it right? but it didnt show. neither the files,  i removed it again from latop and same way connected to pc and all fiels are there with 150Gb space also used.
why files not showing on laptop and showing on the pc?
https://linustechtips.com/topic/300263-urgent-help-pls/#findComment-4078457
-snip-
can you remove it and attach it externally and check it if the date persists or missing
PCPartPicker
https://linustechtips.com/topic/300263-urgent-help-pls/#findComment-4078476
well, fuck me. i deleted this folder named $recyclebin and now the drive is not fucntioing at all. when i connect to laptop it does nothing and when connect to pc it does not even let my pc run which is to boot from  850 Pro
https://linustechtips.com/topic/300263-urgent-help-pls/#findComment-4078609
  • 2 weeks later...
can some one help me with this? how to fix it?
now when i boot the laptop nothing happens only the acer logo appears. i can not even see the setup or boot menu option F2 or Del.
when i connect it to pc via SATA cable, my PC gets jammed. nothing happens and its just stopped. nothing happens, although my windows is installed on 850 Pro.
can some one help me? and yeah i can see it in the  Disk management after like 15 min of opening it. can some one help me or is it dead?
EDIT:
so i closed the laptop lid and now when i open it, im in the blue menu where all the hardware info is, i.e its like the BIOS settings. i CAN SEE WD Blue WDC WD500LPVXTT0
pls guys help me, i dont want to go to local repair shops, they charge almost as much as the drive costs to fix them. and its way too far from my house :(
https://linustechtips.com/topic/300263-urgent-help-pls/#findComment-4158125
- snip -
Laptop C: drive.
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/300263-urgent-help-pls/#findComment-4161646
Laptop C: drive.
https://linustechtips.com/topic/300263-urgent-help-pls/#findComment-4197296
Glad it got solved
PCPartPicker
https://linustechtips.com/topic/300263-urgent-help-pls/#findComment-4198301
