Hello everyone.
I'm going to build an gaming machine inside the "Corsair 380T" case (I love that case :P)
Anyway I have made a build on pcpartpicker and I want to know what you think of the build, do I need to change anything or something like that.
I'm also pretty unsure about the power supply, is it good enough or what :P
Anyway here is the build
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.95 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($88.98 @ OutletPC)
Motherboard: Asus MAXIMUS VII IMPACT Mini ITX LGA1150 Motherboard ($218.99 @ SuperBiiz)
Memory: Corsair Vengeance LP 16GB (2 x 8GB) DDR3-1600 Memory ($159.99 @ Amazon)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($104.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($44.99 @ Amazon)
Video Card: Asus GeForce GTX 980 4GB STRIX Video Card ($549.99 @ SuperBiiz)
Case: Corsair 380T Mini ITX Tower Case ($114.99 @ Micro Center)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.99 @ Newegg)
Total: $1552.86
Generated by PCPartPicker 2015-01-28 20:14 EST-0500
Anyway if you change something then it would be nice if it's about the same price.
-007Mix
https://linustechtips.com/topic/300164-mixs-mini-itx-build/
Hello everyone.
Total: $1552.86
-007Mix
FYI H100i won't fit ; I know from personal experience
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
https://linustechtips.com/topic/300164-mixs-mini-itx-build/#findComment-4076987
Corsair lists the H100i as compatible. What was the issue you ran into?
@007Mix,
The CX-500M is an ok psu. SeaSonic M12II 520 Bronze or Antec HCG-520M would be better IMO.
Mushkin Blackline 16GB (2 x 8GB) DDR3-1600 Memory and PNY XLR8 16GB (2 x 8GB) DDR3-1600 Memory are both good quality lower cost memory kits with slightly better timings than the Kingston kit.
https://linustechtips.com/topic/300164-mixs-mini-itx-build/#findComment-4078975
Hello everyone.
Total: $1552.86
-007Mix
Hey 007Mix,
The build looks good. I would call Corsair's support and ask specifically about the H100i.
Also, I don't think you need 16GB of memory for a gaming build. 2x4GB would be enough.
The PSU is enough, but I would go with something more powerful since you have some pretty strong parts there and you are going to overclock the CPU. I would switch to something like a 600W gold-certified PSU just to be on the safe side and have more space for overclocking and future upgrades. :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/300164-mixs-mini-itx-build/#findComment-4079027
Hello everyone.
Total: $1552.86
-007Mix
Like @Captain_WD said consider a more wattage and better rated PSU as you have more headroom that way you have to remember that a PSU doesn't run always on that 500W.
https://linustechtips.com/topic/300164-mixs-mini-itx-build/#findComment-4079206
