Need help with RAM
Solved by tmlhalo,
CL13? That's gonna be even worse than the current stick I have with CL...
Your motherboard can support 1866 Cas 10. That was simply an example one I picked from Cruical's products to show that 1866 MHz is supported. Also the 1866 MHz cas 10 has better latency than the 1600 MHz cas 9. Cas latency is based on clock speed. You can see this chart here for how many ns it takes to get the first, 4th, and 8th word from memory.
http://en.wikipedia.org/wiki/CAS_latency#Memory_timing_examples
